Results 1 to 7 of 7
Thread: I can't get my 79 started
    Feb 2003
    Delano, CA
    616
    I got my 79 110 finished. I got it running for about 15 secs. then it died. The spark plug is wet, it has spark. I pulled it out, pulled the motor slowly and it sparked. How do you set the timing? You line up the silver side of distributer or the rusty side of (pics enclosed) to the black box with F lined up the timing hole. I also need to put a washer on it.
    It has a 84 motor in it because my cousin pulled the 79 motor out and put in the 84. So the 79 has a 84 setup for now.
    I also posted a pics of both of them.
    (edited by wickedfinger)
    1979 Honda 110 ATC, CEET gas tank cover, 25X11X9 rear tires
    1984 Honda 110 ATC, orignal blue plastics,
    1982 Yamaha 175 TRI-MOTO, 26MM Mikuni
    Honda US90 ATC, Collecting Dust
    2004 TRX450R
    Washingtons Crossing, Pa.
    2,977
    email me the pics and I'll resize them and edit them back into the post for you. Tejas10@aol.com
    2,977
    Fixed .... pic was a little blurry.
    Chemical442's Avatar
    Chemical442 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Central IL
    204
    Pretty much all you have to do is make sure the "O" mark on the cam sprocket is lined up with the mark on the head at the 9 o'clock position when your "T" mark on the generator is lined up with the mark at the 9 o'clock position on it's case.
    See diagram below or go HERE for more picts. I just got my 79 running last Sunday night. My timing was off one tooth mark. Chain must have slipped on me during reassembly.
    • Rebuilt '79 110
    • Rebuilding '82 200
    Feb 2003
    Delano, CA
    616
    Will I got it running last night. I lined up the silver dots with F on the flywheel and it started right up. I don't think it made my neighbors happy last night, I started it up about 10:30 last night with no exhaust. Now I need to get my right rear tire fixed AHH! it has a hole in it.
    2004 TRX450R
    FullBore is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    They do sound good without an exhaust on them LOL
    1979 Suzuki TS100
    1984 ATC70, Broke
    1984 ATC110, Repainted and Rebored.
    1990 Suzuki SJ410
    Unsuspended Antics.
    Central IL
    204
    Quote Originally Posted by FullBore
    Yep, and the valves don't tend to get sucked out due to lack of back pressure. :shock:
    • Rebuilt '79 110
