Results 1 to 3 of 3
Thread: Yamaha 250 Help
    Apr 2006
    Cornell Illinois
    31
    Yamaha 250 Help
    Okay, i have a yamaha 250 that i just bought like 4 days ago and the engine blew that night. I dont want to part with the machine so can someone tell me what i should do about it. Ive been told to bore out the engine and others have said to get a new one but i dont know where to get one and perferably thats what i would like to do is get a new one because i have the money and i love the threewheeler so if someone can tell me what they would do then that would be awesome thanks. anyways if any other info is needed on the matter message back!
    Sep 2005
    central Illinois
    651
    I'd pull the engine out, and check the piston and cylinder to see what they look like. Chances are you can get an oversize piston and get it bored out
    Aug 2004
    Ab Canada
    4,368
    Bore,piston, rod kit, main bearings, crank seals, Head+base gaskets, Clutch cover gasket, and labour, Not to mention Why it blew in the first place, (money on the impeller, unless it was just really worn), your looking at close to a grand if not a little more to have it done properly, and thats pretty much, you pull it out n drop it off at a shop.
    1985 Tri-Z-
