Thread: carb trouble
    drhatc200's Avatar
    drhatc200 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2007
    northcarolina,wilkes county
    214
    carb trouble
    got a 85 200x carb that want idle. took apart and cleaned it out good still dosent want to idle stock carb also lost bolts in yard to my skid plate anybody know what size i need.
    Aug 2007
    Moab, UT
    1,807
    Did you knock the emulsion tube out and clean that out, did you poke through every little orifice in the carb with a tip cleaner, is your idle air screw adjusted properly, did you blow through every hole in the carb with compressed air and spray carb cleaner through them to see if it's coming out where it should? There is alot of variables here is what I'm saying. Some peoples ideas of cleaning a carb consist of removing the float bowl, spraying it out, and then putting it back together. A stretched cam chain can also affect your idle and performance. So can low compression.
    drhatc200's Avatar
    Dec 2007
    214
    ok yes we took the jets out and cleaned allof them.not sure about the idle air screw.ok another thing is that it want crank by kicking it but can roll it off and cranks good. blows alot of white smoke rings gone not giving enough compression to kick strat it?
    Aug 2007
    Moab, UT
    1,807
    Yes your starting problems are most likely to be caused by low compression. Those first gen X motors are a real beotch to start with low compression. That's prolly why she won't idle either. Your idle/air screw should be set at 2 1/4 turns out from fully seated.
    Apr 2007
    Springfield, PA
    889
    get a carb rebuild kit, and if you want do the top end of the engine.
    My Rides
    1983 ATC200 - U-Haul edition - great mudder - SOLD
    1984 ATC200X - sucked a valve - frame up resto & engine rebuild with performance parts in the works
    1987 Suzuki DR200
    199? Go-ped Sport
