Page 3 of 3 FirstFirst 1 2 3
Results 31 to 40 of 40
Thread: To try...or not to try?
  1. #31
    rckstrgrl21 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    Carlsbad, Ca
    235
    well can anyone get me the parts for cheaper? And can anyone here machine it for me (who is skilled t it)?
    1985 Honda 200x
    ~K&N Airfilter
    ~Cobra Exhaust
    ~Holeshot Wheels
    ~Re-Jetted Carb.
  2. #32
    Kentucky
    2,294
    Well, I can but it will be a couple more weeks. Getting ready to open my own shop and I"ll be selling parts dirt cheap.
    Tionesta Trikes ATC 450R
    86 250R
    86 Tecate-3
    83 ATC 70
    85 Big Red
    81 KLT 200
    85 250SX
  3. #33
    Quote Originally Posted by storm_impulse View Post
    ok? why would i need this list? i done a rebuild on 2 diffrent ACTUAL 200x engines so i know what to look for and what needs replaced. i was just stating that your rebuild quote was off. Above you say you performed all the work huh? so if you did all the work why did the bore cost you 75 bucks? By the way. i like your little snappy names you made up. meatball, chippy, again wtf? how old are you? i wouldnt doubt you do shoot popsicles out your ASSES for fun.
    "ACTUAL REBUILD MIND YOU OF AN ACTUAL 1985 ATC200X - 8/2007"
    why would it not be actual? is it imaginary?
    There not popsicles, they're the push up rockets colored red/white and blue
    You didn't seem to believe the quotes I thre out there, so I posted the rundown of prices and labor.
    The prices I quoted were from a rebuild that I performed on the same exact model, just a few months ago. Not someone pretending to know what I was talking about (no, that is not in reference to you; although it could be, I'm not sure because I don't know you). 60$ - 75$ is the average charge for boring and honing a cylinder. That type of labor would be called "machine shop services" not the assembling and disassembling of the engine. Last I knew, not many of us had a "boring machine" in our tool box
    Truth of the matter is we didn't even discuss the possibility of crank bearings, a connecting rod, clutch, oil pump or kickstarter gears. I don't know what her motor is gonna need and neither do you. It could be as cheap as 300$ or as much as 1000$ and there is no use sugar coating it. I personally wouldn't want to be 2500$ deep into a 200X, but that might be just fine for other people; to each there own........
    There are plenty of posts here of guys trying this, trying that, fixing this, fixing that and lots of times the work doesn't last and or has to be repeated.
    Build it once, build it right and be done with it.
  4. #34
    Oregon
    2,471
    Best thing to do is Sell the ATC 200X , Buy a '85-'86 ATC 250R , 2 Stroke
    And if you need to re-build it , it's cost is way cheaper
    On the Plus Side you'll have a Way Better Start to a Race Machine .... Easy to up-grade on Parts ...
    Put it this way , if you were starving... would you take a Grape-(200X) or a Mango-(250R) ? ? ?
  5. #35
    Quote Originally Posted by ceaserthethird View Post
    THAT is good advice
    It certainly has ALLOT better chance of keeping up with your friends 450 and 500 even with the 250R in stock form.
    A 350X is another ATC that has plenty of power and good suspension.
  6. #36
    storm_impulse is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2007
    west virginia
    291
    THAT is good advice
    that is true. rckstrgirl even if you was to fully mod out the X its not possible to keep up with the 450's and stuff. id say if the 85X was created with a 6th gear there may be a chance. when i did my X up i was able to get 63 mph and that was mainly messing with the gearing, and smaller tires.
    1986 atc 250R. needing alot of parts. winter projet!
    1988 lt 250r quadracer. building now.
  7. #37
    Nov 2006
    southern oregon
    2,338
    That is definately some solid advice... R's are cheap to build/rebuild... and have rediculous potential...
    2-stroke lover
  8. #38
    Nov 2007
    Carlsbad, Ca
    235
    Selling is not an optoin right now. I have gone through this before about a month go, and I realized that I just want to restore this one (not showroom, but decent) upgrade it, keep it, and later I am going to buy a Yamaha Raptor (Yes a 4-wheeler).
    1985 Honda 200x
    ~K&N Airfilter
    ~Cobra Exhaust
    ~Holeshot Wheels
    ~Re-Jetted Carb.
  9. #39
    Oct 2007
    Grosse Tete, LA
    3,441
    i'll tell you what's sad... a 10.25:1 wiseco is 84 dollars AT COST! that's bs. especially when just a replacement piston is only 40...at cost.
    personally i would say do not get a lifan... they are actually built pretty well. and they are brand new, but my 22 year old X engine with just a fresh piston and rings was faster. then again, i think the internal gearing may be a little closer, so it may simply be the gearing.
    i'd rebuild the stock X engine if getting another bike isn't an option. but take it from someone who has gone the path you are, it's gonna be a money pit. DEFINITELY. a fun money pit, but still.
  10. #40
    drhatc200's Avatar
    drhatc200 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2007
    northcarolina,wilkes county
    214
    this is starting to tell me i bought 100 to turn it into 1000. not good at all.but tax time is around the corner im going the same route as you got a 85 x smoking but i ahve another engine to stick in it so i can build the other one.
