Results 1 to 8 of 8
Thread: ohtsu/dunlop tire question
    Nov 2006
    Ga
    103
    I have had a terrible time trying to locate a OEM replacement Ohtsu front tire for my 200x project, I know Dunlop has made a replica 23x8x11 but where is the best place to get one? Does it have a name like the P/V Ohtsu?
    84 Tri Zinger 60
    84 ALT 125
    84 ATC 110 (blue)
    85 YZ 490
    85 ATC 125M
    85 CR 500
    85 Tri Z 250
    85 Quadracer 250
    86 Tri Z 250
    86 ATC 350X
    (2) 86 ATC 250R
    86 Tecate 250
    87 ATC 200X
    87 ATC 250SX
    (2) 87 Big Reds
    88 Quadracer 500
    01 CR 500 (new)
    04 KX 500 (new)
    06 Banshee SE (new)
    07 CR 125 (new)
    07 CR 250 (new)
    atcman77's Avatar
    atcman77 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2007
    NorthEast, PA
    185
    Quote Originally Posted by prohemi500 View Post
    The original Ohtsu “Pro Vector” or “P/V” front tires were discontinued some time ago.. You will see them run across Ebay occasionally brand new but they generally bring between $150 and $300... Just depends on who is looking for one at the time.
    Dunlop still produces the KT576 which was OEM for the front on the 85 ATC250R. Those generally run between $45 to $60 depending on which distributor you get them from.
    Quote Originally Posted by An Anonymous Member
    Do you really have to type (PM sent)...............
    ATCT is offline Just Too Addicted Arm chair racerJust too addicted
    Dec 2005
    Phoenix, AZ
    709
    If it's for your '87 X, this is the part number for the front tire: 44710-HA5-672AT. I'd try Service Honda or Honda Parts-Direct to see if they have it first. Otherwise, the Dunlop is really similar (unless you're going for a spot on restoration).
    You can get the Dunlop here. http://www.motorcycle-superstore.com...ront-Tire.aspx
    1984 Honda ATC250R
    atcman77's Avatar
    Feb 2007
    NorthEast, PA
    185
    The OEM Ohtsu 23x8x11, 23.5x8x11 and the optional replacement 24x8x11 are long gone from dealer stock. There may possibly be a dealer in the states with a couple still sitting on the shelf but good luck locating them! You can find them used, in like new condition, still mounted to the original rim on Ebay occasionally. There are a couple listed on there now but if you prefer brand new and aren’t doing a 100-point restoration…. Then the Dunlop KT576 is the cheaper option!
    Willamstown PA
    5,824
    cheng shin makes a 23.5 x 8 x 11 tire tat is pretty close to the oem style... i have on on my 200x
    Dec 2005
    Phoenix, AZ
    709
    Depends on the year. For the 83-85, you're exactly right. I actually just bought one of these for my '83 R. Almost exact, including the sidewall tread pattern.
    http://www.northerntool.com/webapp/w...0627_200330627
    1984 Honda ATC250R
    Nov 2006
    Ga
    103
    Thanks for the help guys, I am (or was) doing a 100 pt. resto. but this front tire and some of the handlebar pad pieces are keeping me from it now.
    84 Tri Zinger 60
    84 ALT 125
    84 ATC 110 (blue)
    85 YZ 490
    85 ATC 125M
    85 CR 500
    85 Tri Z 250
    85 Quadracer 250
    86 Tri Z 250
    86 ATC 350X
    (2) 86 ATC 250R
    86 Tecate 250
    87 ATC 200X
    87 ATC 250SX
    (2) 87 Big Reds
    88 Quadracer 500
    01 CR 500 (new)
    04 KX 500 (new)
    06 Banshee SE (new)
    07 CR 125 (new)
    07 CR 250 (new)
    Utah
    644
    Dunlop is reputable, and I would consider them an equivilant on a total restore. I consider them more oem than aftermarket.
    A few wheelers, + an
    '73 Honda 49cc Mini Trail
    '85 200 Big WHEEL
    "Despite the cost of living, its still popular."
