At The Back Of The Pack
Arm chair racerAt the back of the pack
Dec 2007
n utah
279
200x rear sprocket and chain adjustment help
Been out looking at the bike. My first problem is the rear sprocket. There is a snap ring on the left side and the carrier?? (swing arm end) on the right side. The sprocket is quit loose and will jiggle back and forth. Is something worn out or can it be tighten by the big nuts on the right side?
I also need to tension the chain. I can see how to adjust the swing arm, my problem is how do you know you have both sides adjusted the same? Just count the turns of the adjusting nut on each side or what?
Yes count your turns and make sure your chain is in a straight line not pulled to either side. your rear sprocket has a rubber cushion maybe they are totally worn out, they are there to help with chain slap on the transmission. have fun! im about to do the same to mine!
...my problem is how do you know you have both sides adjusted the same? Just count the turns of the adjusting nut on each side or what?
behind the chain adjusters, on the frame their should be about 5 little vertical lines, when you adjust the adjusters make sure both are lined up with the same amount of marks on each side of the frame. see the pic.
My Rides
1983 ATC200 - U-Haul edition - great mudder - SOLD
1984 ATC200X - sucked a valve - frame up resto & engine rebuild with performance parts in the works
1987 Suzuki DR200
199? Go-ped Sport
Almost all 200X's have play in the rear sprocket hub. It's not a huge deal, but it isn't going to get better on it's own, and it's hard to find good sprocket hubs now. Unless you can still buy them new?
I've never checked,I doubt it though.
Mine was pretty bad but I was lucky enough to have one come on the axle that I bought off a member on here.
It was still loose, but definitely better.
Arm chair racerFirst time rider
Dec 2007
northcarolina,wilkes county
214
well mine is throwing the cahin if you hit it real hard. dont know if chain just needs adjusting havent had it but it week.but my sprockets moves quit a bit
