Results 1 to 14 of 14
Thread: Master link clip: post your technique
    Phoenix, AZ.
    6,719
    Seems like by the time I need to put one of these on, I forgot how I did it the last time. I think I just screw around with it until the little *Edited**Edited**Edited**Edited**Edited**Edited**E dited* snaps in there. I was putting a new chain on the 350x today and started thinking there's probably a good technique for this that I'm missing.
    Oct 2007
    Grosse Tete, LA
    3,440
    use some needle nose pliers. slide the clip on, then catch the clip and the link with the pliers, squeeze and it's done.
    works like a charm.
    If it's an oring chain then it's a press fit. I use a 1/4-20 nut and with vice grips I work the plate back and forth until it is seated over studs and the orings. Then I take n n pliers and put the closed end of the clip on the front stud facing up or 90 degrees from the chain upwards. Then I rotate it down and use a teenie tiny screwdriver to flip the lower open side of the clip over the rear stud and - VOILA - she's done.........
    Phoenix, AZ.
    6,719
    Now I have an excuse to finally go buy a new pair of needlenose pliers. I remembered doing it that way a long time ago as soon as I read your post. Can't for the life of me remember how I did it last time though.
    Sep 2007
    British Columbia, Canada
    818
    You know, about a week ago I was thinking the exact same thing.
    I just mess with it too, I eventually get it, but there HAS to be a better way.
    I usually end up doing the pliers method, but even that sometimes gives me trouble, usually only when it's new and still stiff though.
    [b]'83 200X-
    White/Blue:
    The 2 stroke 200X
    Vids:http://youtube.com/watch?v=HwDqUVM9jOo
    McDerry is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Maine
    440
    Linesman Pliers work much better.
    Aug 2005
    Lockport, NY
    2,395
    Just get the masterlink pliers they sell. End all of the god forsaken misery. I believe Parts Unlimited has them.
    Phoenix, AZ.
    6,719
    Hell I didn't even know there was such a thing as master link pliers.
    Apr 2006
    PA
    1,464
    The way i do it on the oring chains is to squeeze the clip and link together with pliers and slide the master link into the grooves, then I take off the pliers and squeeze the middle section and slide it in with my finger or until its touching the other pin, then tap it in with a .
    Howdy's Avatar
    Celina, Ohio
    10,079
    Modified Vice grips work flawlessly. I ground the tip to fit in the middle of the clip. The retainer clips slips right on.
    Howdy
    Phoenix, AZ.
    6,719
    That bold part was the key. That and digging out a work light so I could actually see what the hell I was doing. I took a 10mm nut and put it over the post/stud/whatever you want to call it on the side the clips go and used vise grips to squeeze the link together. Once I had some adequate light I could see I wasn't exposing enough of the groove. I couldn't get the o-rings compressed enough until I used the nut trick. The clip went on smooth as silk after that.
    Great tip Dirtcrasher.
    hey howdy, post a drawing of your tool.
    one cylinder is not enough!!
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by Howdy View Post
    Howdy
    I use a vise grips as well.
    I guess you know to always put the open end of clip opposite of rotation.
    Apr 2006
    Crestview, Florida
    2,429
    You can buy chain tools in the bicycle section at Walmart.
    I always use pliers or a flat head screw driver. It's easier with the chain off of the rear sprocket so you can fold it at the master for easy access.
