Page 4 of 10 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 46 to 60 of 146
Thread: ascott 500 head swap onto a 350x.... with pics
  1. #46
    scrawny's Avatar
    scrawny is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    WI
    181
    Quote Originally Posted by SWIGIN View Post
    i do know a guy with a new atv dyno....hmmmmm
    let me be the first to guess...
    im going to say 44 hp. ever figure out what compression its going to end up being?
    thanks for the sig
    sponsorhouse.com profile: http://sponsorhouse.loopd.com/Member...er65/Home.aspx
  2. #47
    PA
    3,515
    yeah im useing a 10.25 or 10.5 ( whatever they call it)
    since the piston is made to be used with this head im thinking the addvertized compression ratio should be right
    im keeping the comp low and the cam on the small side to lenghthin the fuse on this time bomb...lol
    you might be real close on the hp guess ...... we will see
    WWW.HREATV.COM
  3. #48
    All nice stuff SWIGIN!!
    Funny though, this just proves what BS is out there. How many of us have read that the "ascott swap" just needed a few minor mods to get it to fit. LOL... Turns out it takes big mods, allot of machining and plenty of brains. At least you have posted it for us all to know what is truly involved in this swap.... Thank you.
  4. #49
    Fresno Ca
    2,695
    Quick question, for you Swigin, Is a ascott 500 cam a drop in for a 350x?
  5. #50
    PA
    3,515
    Quote Originally Posted by NOS_350X View Post
    i would think so....i have a xr500 cam witch should be the same as a ft500 and it fits perfect in the 350x head
    edit..... on second thought i know its a direct fit
    WWW.HREATV.COM
  6. #51
    PA
    3,515
    thats 100% why i posted all this
    its crazy all the crap out there you hear about this swap.........now get to work....lol
    WWW.HREATV.COM
  7. #52
    scrawny's Avatar
    Nov 2007
    WI
    181
    about the cam swap:
    do the pistons deck out the same between the 500 and 350x? you might run into piston/valve clearance problems. just a thought...
    thanks for the sig
  8. #53
    PA
    3,515
    the 500 piston pin is like 3mm lower then the 350x so the piston is higher but powroll knows this and shrinks the rod the extra amount.
    if you had a old streched timing chain you could also run a 3mm cyl spacer
    in other words my 500 piston will be as the 350x highth and lower then the 500 highth so valve clearence will be nothing to worry about
    WWW.HREATV.COM
  9. #54
    scrawny's Avatar
    Nov 2007
    WI
    181
    no i meant running just the 500 cam in a 350x, like NOS said.
    thanks for the sig
  10. #55
    PA
    3,515
    it will work since the xr500 cam is not much different then a stock 350x cam spec wise
    stock 350x specs... .313 .303 lift 221 221 dur
    i dont have stock xr500 cam specs but here is mega cycles smallest drop in cam
    .333 lift 234 242 dur
    i would think a stock 500 cam is not even that big
    now heres the 350x race cam iv used in the past
    .405 lift 249 dur.... with any cam you need to check for clearences
    but whats so nice about this head swap is i can use all the xr500 cams without any special clearnceing other then the normal need to maybe shorten the guides and check piston clearence
    if you want to see the 2 cams im thinking about its megacycle #144-20 and #144-21 but im leaning toward the smaller #144-20
    WWW.HREATV.COM
  11. #56
    scrawny's Avatar
    Nov 2007
    WI
    181
    good info to know!!
    ya got me lol! ive only got the biggest web cam which is as follows: .392 lift and 279 duration. runs good likes to rev. especially with the relatively small 82mm wiseco and a stock stroke.
    thanks for the sig
  12. #57
    Oct 2007
    Grosse Tete, LA
    3,441
    is any other topend just a bolt up? machining the cases if the sleeve doesn't fit, but besides that.
    I'm doing a highlift cam, but i'm curious about air flow, seems like it would benefit from a lot more.
  13. #58
    PA
    3,515
    Quote Originally Posted by The Goat View Post
    sorry man, im not following you
    this dont just bolt up if thats what you mean, and you dont think this head will not give enough air flow?
    WWW.HREATV.COM
  14. #59
    Oct 2007
    Grosse Tete, LA
    3,441
    lol...if you calculate when that post was written you'll see it was at a very random hour. I've been up since....jeez...uh 2 p.m. thursday. exams this week.
    your headswap is perfect, but, it's also a bit more labor intensive, and expensive than i was looking for.
  15. #60
    I think GOAT was asking if any other larger topend was close to a bolt on a 350X with maybe some case work but not all the intense work - drilling/welding/fabricating that goes into this ascott head swap.
