Results 1 to 8 of 8
Thread: Ice tires for 10" rims...need some input
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    Just wanted to get some input on tires that work well screwed for ice, for 10" rims.
    The cheaper the better, but not too cheap, if you know what I mean. Just something that won't break the pocketbook.
    I was thinking maybe some Turf-Tamers, something like that, but I'd like a nice flat profile, for the track we have here locally. I've not done it in quite a while, so I'm a little rusty at knowing what works and what won't. I'd like to stay at 18 or 20 inch tires like I have on my R right now.
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    Fort Smith AR.
    44
    I would think the fast trekkers would work pretty good, becuse they have a really flat profile. You can still buy the 18" blems for around $80 shipped.
    Aug 2007
    Moab, UT
    1,807
    There's only one good tire for ice racing and that is the Cheng Shin C826. It's flat profile, hard knobs to hold the screws, and dirt cheap. But, 20in is all you can get for a 10in rim, and 20s are no good for ice racing. Trust me.
    Aug 2007
    Moab, UT
    1,807
    This is what you should run
    InPiEcEs's Avatar
    Apr 2004
    Northeast Wisconsin
    378
    I assume those would be the C826's, right.
    They look pretty similar to what we used to run. A simple flat profile knobby with lots of room for screws.
    Thanks Ninja........by the way, how do those work for ya?
    1995 CBR600F3
    Aug 2007
    Moab, UT
    1,807
    They are the Chengs I was talkin about, they are 18/9.5/8. They work extremely well for me. They get traction on ice almost as well as running stock knobbies on pavement. Where exactly are you from in WI? I used to live there.
    InPiEcEs's Avatar
    Apr 2004
    Northeast Wisconsin
    378
    Well....I decided to run the screws to my Fast Trekkers.
    I'm running the 18x11-10's, and a Dunlop "stocker" in the front.
    The front pattern I think will be fine. For the rear, I ran 7 screws into the bar lugs, and 3 in all others, and one in every other small outer lug. I haven't had it on the ice with this set-up yet, so I'll find out soon how it worked out.
    I'll post a pic or two once I get the chance.
    1995 CBR600F3
    Jan 2008
    Wisconsin
    I run the C826's on mine also. I was told that you can't buy the anymore. But, If you want a set I know of a shop that bought what Parts Unlimited had left. Where in Wisconsin are you. I live in Fond du Lac.
