Do you run a wide rear end, how? which brand of axle? wheel spacers? do you run a non Kawasaki rear end? and
Do you run an extended swingarm, what brand is it? What length?
Thankyou in advance
Thankyou in advance
My toys 85 KXT250A2, 85 ATC250R, 85 Tri-z 250, 06 LT-R450, 04 YFZ450S, 07 125 typhoon x 3, 06 FPV GT.
I just bought a '86 roller and have a long way to go before riding it, but I put 300ex rear hubs on the stock axle which made it wider. I'm not sure exactly how much wider because I didn't measure the stock width first- 2 to 3 inches total I think.
Thanks for the reply. Do the 300EX hubs fit properly or are they a bit loose/tight?
Has anyone else mixed and matched rear end parts on a 2nd Generation Tecate?
i have a 6 over swing arm on mine and 3 inch wheel spacers. also i run banshee hubs for my paddles so i can run a 8 inch rear wheel.
heres my 86 with my 85s bearing carrier, axle, and 84 hubs and wheelspacers on it. bolts right up. and i left the sprocket and rotor right on which also line right up. i have the stock carrier and axle back on it rght now cuz i was just seeing what it would look like widened, i love the look. i am going to be getting some 4x156 durablue easyfit wheelspacers for it eventually, will give me 2.5 inches of width on each side.
I don't have pictures to post on the new computer yet. i got to do some transfers lol. But i did a site search and found the picts of my 87 T3 rebuild.
Here is the build post... http://www.3wheelerworldforums.com/s...ad.php?t=47329
a few picts of the rear end...
http://www.3wheelerworldforums.com/a...1&d=1149311420
http://www.3wheelerworldforums.com/a...2&d=1149311420
Thats a plus 4 i found is a salvage yard w/ a crazy-G bolt in 6in extender.
I love it, it works great.
MIK6 / Mike
New England Ride 4/13
Thanks for the feedback guys.
Scooteroo, Your 86 is comming along nicely. I'm a fan of the white frames. I can't decide to between White or Silver for my Tecate which goes into the powdercoater next week. Have you got any side on photos of the 86 with the engine in it?
Mike 6, that swingarm extender is good stuff, nice axle too. Your rims are beat up pretty bad. They wouldn't be light gauge douglas rims would they?
200x350xtriz250, thanks for the info.
If anyone else has a hybrid rear end on their Tecate speak up....
From post:
http://www.3wheelerworldforums.com/s...385#post456385
"AS for the 86+87 you can use a tecate 4 axle.
I have been keep this under my hat for alittle while,after that ordeal with the decals I swore I'd never help this stite again.I give you 1 more chance.
there are 2 things you need to know.
first: you can only use the eliminator axles.the tecate 4 is shorter then the tecate 3.so a plus 4 is only going to be +2 or stock.
second: you must use a rad lock nut there is not enough threads for double nuts.
THANKS TRIZTUNES!!!!!!"
(Seems the above post was deleted)
http://www.3wheelerworldforums.com/s...ght=400ex+axle
86 T3
84 T3
86 KX250
Thanks fro the links nd4speed
I PMed 3wheels4ever and he gave me the good oil on fitting a 400EX axle to a T3 carrier. It sounds like the way to go.
I was just wondering if anyone else had tried any other combinations.
with the 300ex hubs a 5/16 spacer will be needed. I also used the Honda's castle nut...felt a little tight but threaded on by hand. pics are a bit blurry but I think you'll get the idea.
Attachment 58687
Attachment 58688
No one else has shown proof of the 400ex axle in the T3.
3wheels4ever was very helpful back then (and now, apparently,) and I hope his idea catches on.
86 T3
84 T3
86 KX250
no motor yet... still trying to get caught up from christmas, lol. but heres a side shot.
Noice Tecate Scooteroo. I'm so tempted to go white. Everyone I ask says I should just keet it standard. I dunno. Is that tank painted?
nd4speed, 3whls4ever sent me the Pm regarding 400Ex axles in a T3 ages ago. You are right, I haven't seen anyone else do it. But thats not to say it can't be done.
I'm in the process of stripping down my Tecate at the moment and I'm going to throw my spare YFZ450 Axle into the carrier and see If I can make it fit. I'll let everyone know if I'm successful.
I think the white frames are definately the best looking tecates... But after having a white frame on my quadracer, I just couldn't do it on my Tecate... Its can be a royal pain to clean, as it shows everything... One trip through some clay mud and it never looked the same again... Although I suppose a trike would be alot easier to detail than a quad..
2-stroke lover
