Here's apic of the cobra for the Tri-Z. It'a old, crusty, and beat up but it gives you an idea.
Tionesta Trikes ATC 450R
86 250R
86 Tecate-3
83 ATC 70
85 Big Red
81 KLT 200
85 250SX
Have you run it? Is it obnoxiosly loud?
No just got it today, will probably be a while before I actually put my Z back together.
86 250R
86 Tecate-3
83 ATC 70
85 Big Red
81 KLT 200
85 250SX
Hmm,, has anyone else run one? first time I'd seen one of those.I bet that would clean up nicley tho.. maybe some jet coating?
The cobra on my 350X is unbearable.Id hate to be riding behind one of those all day. Kinda why I'm curious about the two stroke. I sure do miss that smell.
When you get a chance.. can we see a better pic of the mouting bracket?
The system that came off my original project looks like that. I almost threw it away last summer![]()
How can you tell if the expansion chamber is Cobra? No mounts for a heat shield?
I might look into getting my blasted with plastic media and then nickel plated, if it is indeed Cobra.![]()
Someone told me this was either a Cobra head pipe or Answer.
I have ran mine,has a liitle less low end punch than DG and more mid and topend pull.It least that is what I felt.
Even with the Dg silencer,The noise level is the same as Dg.Not bad.
Proudly NOT a member of
"Team on the Teat"
86 250R
86 Tecate-3
83 ATC 70
85 Big Red
81 KLT 200
85 250SX
