Results 1 to 15 of 23
Thread: help on 350x carb?
    350xrider911 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    porter texas
    301
    help on 350x carb?
    ok i tryed everythange except for gettting a smaller pilot jet the. onlt time it idles is when u take the idle screw and idle it realy high, colde it be my port job, or exhaust im runing stock exhaust on a modified motor. it would never idle when it was stock to, what is the stock pilot jet.
    springville, PA
    6,185
    pull your spark plug and see what color the porcelain is. I'm guessing its running too lean on the idle circuit
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Nov 2007
    porter texas
    301
    i dont get how it running lean it smoking i started it up today, and the smoke smelled like almost pure gasand when i opend it up it stops.
    Apr 2006
    Crestview, Florida
    2,429
    valve adjustment
    Rides
    85 ATC350X
    85 ATC200X
    Nov 2007
    porter texas
    301
    im running a 42 pilot
    Nov 2007
    porter texas
    301
    a 10. 5 piston bored half over port and polished head,some of the exhaust stuff cut out of the muffler k&n filter. and it a blue ish smoke and makes *Edited**Edited* eye burn i know i should run primem fuel but im running i than 87
    Nov 2007
    porter texas
    301
    i was reding another form and do u turn the pilot jet all the way in tell its stops or does it need to be ajusted, and on the air to full mixture if u turn it out does it get liner or the other way around.last time it did this the rings froze to the piston and in afiad it will do it again. the trike will load up on gas then die if its about to die, ill give it gas the rev it up and it turns to black smoke should i get a smaller pilot jet. andrun hiher octange full?
    Nov 2007
    porter texas
    301
    ok i just checked what my pilot jet it, and it a 45. but i have an 86 and same size pilot ans it idles every now and then but when i took of the carb there was gas in the intake boot.
    scrawny's Avatar
    scrawny is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    WI
    181
    how is your air filter? a dirty one will make it run erratic. make sure the intake boots are in good shape and not leaking, both the air box and on the head.
    are your valves in spec?
    thanks for the sig
    sponsorhouse.com profile: http://sponsorhouse.loopd.com/Member...er65/Home.aspx
    Nov 2007
    porter texas
    301
    yeah .0003 or .003 one of those the same as paper the air filter has some dirt it wouldnt hurt to be done
    Nov 2007
    porter texas
    301
    would a 86 modle 360x help me. it 34 mm and a 85 ,is 31?
    Apr 2006
    Crestview, Florida
    2,429
    Turn the mixture screw all the way in then back out 1.25-1.50 turns.
    The jets should be tightened all the way.
    Try running a very smal stran of wire through the pilot jet to clear any trash. Also make sure your fuel cap is venting, you can check by blowing or sucking on the vent hose on the cap.
    Rides
    85 ATC350X
    85 ATC200X
    scrawny's Avatar
    Nov 2007
    WI
    181
    oh yea, make sure the petcock is flowing at a good rate too.
    thanks for the sig
    Nov 2007
    porter texas
    301
    ok i put the bigger carb on, and it was easy starting but it ran like crap it would back fire and i thought i would try and take it down the drive way it back fire and nothing but a big black cloud cam out so i shut it down and changed carbes and it ran fine i put a supertrapp muffler on and, it smoked but i thank it from the priviuce three wheeler cuzz it needed rings.
    Apr 2006
    Crestview, Florida
    2,429
    Quote Originally Posted by 350xrider911 View Post
    You can't just throw a bigger carb on and go, you need to jet the bigger carb for your setup
    Rides
    85 ATC350X
    85 ATC200X
