Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: help on 350x carb?
    350xrider911 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    porter texas
    301
    yeah but the carb was off an 86 only 3 mm bigger?
    Apr 2006
    Crestview, Florida
    2,429
    Different jetting
    Rides
    85 ATC350X
    85 ATC200X
    Nov 2007
    porter texas
    301
    i dont get it was it running rich or lean to back fireim afriad it might run to rich and mess the rings up.would running it lean make the rings stick the the piston also?
    scrawny's Avatar
    scrawny is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    WI
    181
    if it is rich it will flubber and blubber with black smoke coming out, if its lean, it will back fire upon hard acceleration. its a 4 stroke, it can run a little lean if you are just making jetting runs. extended high rpms while running lean will shorten engine life for sure not having anything to do with stuck rings...
    thanks for the sig
    sponsorhouse.com profile: http://sponsorhouse.loopd.com/Member...er65/Home.aspx
    Nov 2007
    porter texas
    301
    i thank i got it figured out when i turn the gas off it idles hight the does smoke as bad but the ill give gas the it act fine tell it run out in the bowl i thank on the 34mm car i need to up jet my main that way it dont back fire and turn the air mixture in as i turn it get rich or other way aroung?
    Fresno Ca
    2,695
    Buy a new plug, Run the bike for about 100 yards at the rpm range/jet you want to check pull the plug you want a skin/tan color (i go for it a bit darker brown to be on the safe side) If there is no coloring then your way lean. Here is another tip always start rich and go down. Rather run rich than blow an engien because of a leand carb while trying to jet in. So if your at a 45 now go with a 52 or 55 pilot and go down. Same with the main jets. Also keep some standards, you keep chainging carbs and pipes, leave it at soemthing and get the jetting figured out, write it down. Then swap parts then it should only be minor changes.
    Nov 2007
    porter texas
    301
    i put a new one in but havent had the chance torun it yet but the old one is all black.
    Nov 2007
    porter texas
    301
    i thank i got it but, still smokes alittle but the spark plug was black knows it brownish , i put the supertrapp on and seem like it had more mid power but i took all the disc out the stock pipe which is modifide alot seem like got more all around power.
