Thread: 86 250R pro-x 330 questions
    Jan 2008
    IN
    4
    I'm putting together a 250R with a pro-x head and 330 kit with a 39mm kehin carb does anybody know what intake will work and what set of reeds i should run?
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    V Force..They are made in NH.
    Jun 2003
    englishtown NJ
    2,676
    I use a 86-98 cr250r rad valve, 1/2" reed spacer and make sure you get fiberglass reeds, not the carbon fiber ones. Much better low end. I have a 310pv, very very similar cylinder and 39 pwk carb.
    Aug 2002
    New York
    1,098
    Ditto....almost. I run a Rad Valve too, but a 40.5mm PWK
