Results 1 to 7 of 7
Thread: What trike should i put this in?
    Mr.Jake's Avatar
    Mr.Jake is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2007
    Ontario
    192
    Question What trike should i put this in?
    I have a 83 200es motor that needs a piston, i was going to get a semi cheap Namura piston but after calling i found out they were discontinued and my only option is a wiseco, which is quite a bit more money. So... should i take my main trike, a 84 200m, take its piston out, swap it into the es, and put the wiseco piston into the 200m, or would it be better to take out the 200m motor and replace it with the es, then id have hi and low gear engine with a wiseco piston in it. Im not sure what to do, so what would YOU do?
    83 Yamaha 225DX
    84 Yamaha 225DX
    84 Honda 200s
    78 Kawasaki 175 enduro
    83 Susuki LT250
    02 Bombardier Traxter
    PA
    3,515
    does pro-x (niks) make a piston for you?
    WWW.HREATV.COM
    drhatc200's Avatar
    drhatc200 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2007
    northcarolina,wilkes county
    214
    ive found piston and rings on ebay for about $60 dollars
    Mr.Jake's Avatar
    Oct 2007
    Ontario
    192
    ive already got it orders, wiseco piston kit, inclided rings, piston c clips, and the little rod that holds the piston to the connecting rod, (forget the name) for $114 can. which come to think of it isnt all that bad.
    Now, if i get this engine running good would you put it into the 200m frame? Or is the 200m motor better?
    83 Yamaha 225DX
    84 Yamaha 225DX
    84 Honda 200s
    83 Susuki LT250
    Nov 2006
    southern oregon
    2,338
    I would put it in the 200m... Low range is sweet...
    2-stroke lover
    Mr.Jake's Avatar
    Oct 2007
    Ontario
    192
    Quote Originally Posted by cr480r View Post
    I'll get it running and check out the tranny to see if it slips any, if not im leaning toward putting it in the 200m , but, heres another idea...
    What if i mounted it into the 250r roller and put a smaller sprocket on the axle... that would mean more speed, and if i wanted to do some thing that required more lower end, i could switch it into low gear, i think that would be pretty slick Any input on that idea?
    83 Yamaha 225DX
    84 Yamaha 225DX
    84 Honda 200s
    83 Susuki LT250
    Dec 2003
    australia
    838
    Put it into the 250R roller, just don't hack up the frame.
    Once you've Had your fun, it can always be retro fitted with a real donk.
    My toys 85 KXT250A2, 85 ATC250R, 85 Tri-z 250, 06 LT-R450, 04 YFZ450S, 07 125 typhoon x 3, 06 FPV GT.
