Page 14 of 39 FirstFirst ... 4 12 13 14 15 16 24 ... LastLast
Results 196 to 210 of 573
Thread: Honda 177X ATC !!!!SOLD!!!! !!!!SOLD!!!!
  1. #196
    McDerry is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Maine
    440
    Quote Originally Posted by edog View Post
    Will it bolt rite up to the fork?
    No, but its easy enough to mod to fit, drill two holes in the fender. Much racier looking then the s fender, yet still wide enough to fill the forks.
  2. #197
    Nov 2002
    Kirkville, NY
    3,831
    Teaser pic.
    Is this why you are looking for 200m front axle? If so, I was under the impression that the 200m uses wider forks and axle b/c of the bigger front tire, aka those are not 200m forks. I am not sure what you are planning, I just know that it sucks buying the wrong parts. So ignore this if it doesn’t pertain.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
  3. #198
    Apr 2006
    Maine
    440
    Quote Originally Posted by thefox View Post
    He may be using a 200m triple with s shocks. The shocks are s model you can tell by how the brakes would attach and the trailing axle (drums on the ditch side of the forks). The 200 STD/M triples is about a inch wider last time i Compared the two, The S model has a large aluminium brake backing plate and drum (heat dissipation) unlike the small steel unit that is on the 200m. A 25x12-9 will almost fit the S triple as in like 1/8-1/4" to tight of a fit. The 200e forks are even wider.
    Mind you if needs a 200s model triple I'd gladly trade one for a 200m triple.
  4. #199
    Apr 2006
    Maine
    440
    All you would have to do is turn the lower fork bodies around to make them look like each other.
    Umm, noo...
    The brake is on the same side on the s and the m model. You turn them around the brake peg hole will be on the outside of the fork, or you swap them side to side and you can keep the brake usable.
    Those are 200s shocks.
  5. #200
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    So they are S forks.Them must have been mis listed.Any body got a S front axle?
  6. #201
    Apr 2006
    Maine
    440
    Measure the top pinch bolts center to center. Should be right around 12". Then you know you need a S model axle. There also a ton more common then the m model axle. A M axle will fit, but you have to drill the shock and use a nut on the backside.
  7. #202
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Quote Originally Posted by McDerry View Post
    Thanks for all the help.
    Should be getting the motor in the next week or 2.
  8. #203
    Willamstown PA
    5,821
    so i check this threas like 1.5 weeks later and its all changed...WTF happened to the flat track trike...looks like a plain 90 with new tires, rims and fresh coat of of paint.....explain to me how thats custom?
  9. #204
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    I changed the theme.
  10. #205
    scrawny's Avatar
    scrawny is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    WI
    181
    any concerns with the lifan tranny/clutch being up to the extra stress of being in an atv that is at least 2x's as heavy and has twice the traction?
    thanks for the sig
    sponsorhouse.com profile: http://sponsorhouse.loopd.com/Member...er65/Home.aspx
  11. #206
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Well I measured 14" 3/4" length from outside one shock to the other outside.
    the fat end is about 3/4"wide.
    I was wondering if the 85 200X bearings hole it the same diameter as the 200S axle?
  12. #207
    Havoxx's Avatar
    Havoxx is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2008
    Miami, FL
    233
    Well after much research,I am most likely going with this motor.It's a couple more $ than the Lifan motor.This is a new Honda laydown motor done up by GPX.
    What the heck is that huge thing? A cooler?
  13. #208
    NE Arkansas
    2,344
    Sweet. An oil-cooled 125cc! Where ya getting it from?!
    My Rags
  14. #209
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Quote Originally Posted by TravEX View Post
    Sweet. A oil-cooled 90cc?!
    Wrong my friend 150cc
  15. #210
    Columbia
    5,131
    Man that thing looks nasty!
    Cough up some cash and finish the dam thing already!
