Page 3 of 19 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 31 to 45 of 277
Thread: 350x the way I like it, with a wide ass
  1. #31
    Oct 2007
    Grosse Tete, LA
    3,440
    yeah...i think it was 300...don't quote me on that, but it was a retardedly high number. wait...268 maybe. and machining of the head if you go with the oversized bearings i think?
  2. #32
    Aug 2005
    Lockport, NY
    2,395
    Goat thanks for the info on megacycles. Everyone always says. Im going to run a cam and high comp piston and blah blah blah, but never puts it in writing about there experiences with any companies. I doesnt sound like they wanted to sell you on all of there most expensive parts or machine work. Good deal and cant wait to see your motor report. I thought someone did a 430 powroll kit a bit ago back on there 350x. I would search the site for that.
  3. #33
    Minnesota
    784
    Sounds like they make a bearing to fit in the journals of a stock head, and they can also bore out the journals for a larger bearing?
  4. #34
    PA
    3,515
    stock 350x hp is 26. something you could get into the 30s
    megacycle is the best to deal with......they live there jobs it seems. not just selling what they are told to.
    WWW.HREATV.COM
  5. #35
    PA
    3,515
    Quote Originally Posted by hrc200x View Post
    yes, if your journals are tore up they can save your head by boring the journals larger for bigger needle bearings....along with the stock size needle bearing cam
    WWW.HREATV.COM
  6. #36
    Oct 2007
    Grosse Tete, LA
    3,440
    is there any particular year 400ex carb needed for the 350x?
  7. #37
    Willamstown PA
    5,823
    400ex's are all the same from 99-08 so year wouldnt be an issue i dont think
  8. #38
    scrawny's Avatar
    scrawny is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    WI
    181
    nope not an issue, newer is always better long run wise.
    after only having my ex carb on my racing frame (that was modified for a bigger carb) i couldnt believe how tight of a fit it is in the stock frame. be prepared for some airbox snorkle mods
    thanks for the sig
    sponsorhouse.com profile: http://sponsorhouse.loopd.com/Member...er65/Home.aspx
  9. #39
    Sep 2003
    Elizabethtown PA
    1,581
    Quote Originally Posted by The Goat View Post
    get a 38mm aftermarket carb will run way better the 400ex ones are not muchh bigger then stock
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
  10. #40
    scrawny's Avatar
    Nov 2007
    WI
    181
    a 400ex carb is a 38 with the advantage of an accelerator pump.
    thanks for the sig
  11. #41
    Sep 2003
    Elizabethtown PA
    1,581
    Quote Originally Posted by scrawny View Post
    your mistaken they are only a 35 or 36 mm carb.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
  12. #42
    Mar 2007
    lakeville ma
    605
    05 and up are better,i forget y but all will do the same thing i think the newer 1's make it easyer to start
    NO 3 WHEELERS CURRENTLY SOLD THEM ALL
    02 GSXR 240 kit STRECHED
    03 BANSHEE 421 CUB
    07 LTR 450
    08 RZR
    05 f7
    07 KLX 110
    670 ho skidoo powered banshee
    1985 nacs kx 80 race quad
  13. #43
    Oct 2007
    Grosse Tete, LA
    3,440
    okay here is a question...400ex riders are upgrading their carbs to the newer 450r model. it's a 40mm. now my question is simple. if the 450r's carb is the better, why not purchase it instead?
    has anyone done this mod?
  14. #44
    Jul 2006
    yea I think some guy on org has done it, but you loose all the duct work for the air box as that carb is alot bigger then the 400ex carb even, you coming next weekend with your homie?
  15. #45
    PA
    3,515
    they are huge and if it fits my frame im going to run a 450 carb on my monster motor when its done.
    the newer 450 carbs are 41mm but that might be the dirt bike carb
    ether way i would not wast the time on a 400ex carb on this motor...you need at least a 38mm. i do know the early ( 04-05) 450r had 39mm carbs if that helps......after 05 honda jumped up to the 41mm or so
    WWW.HREATV.COM
