Results 1 to 7 of 7
Thread: float ajustment
    350xrider911 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    porter texas
    301
    float ajustment
    how do u ajust the floats on a 350x
    Apr 2006
    Crestview, Florida
    2,429
    you dont
    Buy a new needle valve
    Rides
    85 ATC350X
    85 ATC200X
    Nov 2007
    porter texas
    301
    some one one here sed u bend a little meatle piece but i didnt know what they r talking about
    Richland WA
    808
    Float should never need adjusting unless its been bent from factory setting. I dont know the X that well, but many floats have a metal tab that touches the float needle. It only takes a tiny bend to mess it up. More likely a leaking needle and seat if its not working right.
    Fresno Ca
    2,695
    There plastic on a 350x soo you dont touch it, You cant.
    you can check it easy by putting a clear hose on the bowl drain and bending it up the side of the carb..open the drain screw..and you should be able to see the gas rise in the hose..the level should be even with the top of the bowl or just under..
    Richland WA
    808
    Uhh hhh uhh hhuh hh He said TANG
    PLASTIC SUCKS
