Thread: tri zinger
    Dec 2007
    runnemede new jersey
    8
    tri zinger
    where do you drill the holes in the exhaust to stop the carbon build up mine is clogged and some people say to drill holes but i do not know where thank you ,,sean
    Richland WA
    808
    There is no such thing. Carbon in the exhaust is oil that didnt burn because the cylidner is too rich. Drilling holes just makes exhaust leaks and oil spooge leaking out of the pipe. When my R is set to around 30:1 or 40:1 oil, there is no exhaust smoke visible on idle. THATS clean. Its all about controlling fuel and improving the ignition.
    Take the pipe off, knock off the big stuff and clean it with Easy Off oven cleaner and a wire brush. Might work to use a high pressure car wash to blow the junk out.
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    No there actually is such a method for the tri-zinger, have you tried a search on it?
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Dec 2007
    8
    yes nothing that explains where to drill holes
    springville, PA
    6,185
    Quote Originally Posted by sean159 View Post
    dont they use 2 different sized exhaust gaskets? One is larger than the other, maybe they were refering to hogging out the stock gasket so it flowed better
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Dec 2007
    8
    no i have the bigger gasket
