Thread: swingarm opts?
    Aug 2005
    SW Iowa
    524
    swingarm opts?
    what do i need to know/measure if i want a longer swingarm on my 84 200x?
    hadar's Avatar
    Rock Island IL
    699
    Brake line, chain and possable suspension adjustment. I think a +2 is the best all arround choice for practical riding. Never had a 200x though.
    Aug 2005
    SW Iowa
    524
    are these arms adjustable at the axle instead of the frame i'm wondering cause of the opened end instead of the circled ones i've seen? also are they available for a 84 200x?
    Danold's Avatar
    Danold is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    barnesville, Ohio
    193
    those swing arms use an adjustable bearing carier compared to a fixed one on a stock 200x. It could be made to fit with some work but you would end up having to buy a different axle and bearing setup.
    85 200x
    85 Tri-z
    86 Bigred
    81 Rm60
    John Deere racing tractor
    Quote Originally Posted by wad
    sorry dude mine are all shitters lol
    Aug 2005
    SW Iowa
    524
    Quote Originally Posted by Danold View Post
    an adjustable bearing carier ?? is this used to take slack out of chain? this is my 1st trike w/suspension so i'm learning as i go thank you. also i have an idea of using my 200e motor (after i have it rebuilt and beefed a bit) but with the subtranny the current location of chain tensioner will most likely be in the way.
