Results 1 to 15 of 25
Thread: tlr200 motor in a 200s PICS! UP AND RUNNING!
    Jul 2006
    iowa
    451
    Well my 200s has needed a rebuild for a while, but I figured why rebuild it when I could buy something a little better? I have never really liked the pullstart and I would rather have a manual clutch than an auto, so I ended up buying this a few minutes ago: http://cgi.ebay.com/ebaymotors/ws/eB...m=260203061482
    Its a tlr200 honda motor from an older trials dirtbike. It should bolt right in, right? I'm hoping to use all the wiring and components from the 200s along with the carb and exhaust (until I upgrade them, hopefully soon). Does anybody see any problems I might have getting this motor running in my 200s?
    Attached Thumbnails Attached Thumbnails motor.jpg   motor2.jpg   motor3.jpg   motor4.jpg
    Tionesta, PA
    5,743
    The TLR motor is almost identical to an XR200 motor - The exhaust and carb are way different. I'm sure you can make it work - but you have a reverse kick start with the TLR motor - not sure how you would do that and keep the 200S bolted on fenders.
    Here is a pic of the wife's TLR
    Jul 2006
    iowa
    451
    I already knew the issue of the rear kicker and im not too worried about that, but do the exhaust and carb attach differently? I'm aware that using the 200s exhaust and carb will be a downgrade until I buy a better system(83-85 200x??), but they will still bolt on and function properly?
    Jul 2006
    iowa
    451
    also, does anyone know what other kick start levers will fit this motor? Im guessing one from an xr200 will work, but are there others?
    Jul 2006
    iowa
    451
    i did notice that it looks like this motor doesnt have the pulse generator on the end of the camshaft. will this create a problem if i try using the 200s harness? what will i do with the 2 wires?
    Jason T's Avatar
    Jason T is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    UK
    341
    The TLR engine is a detuned xr engine. You get the advantage of the 6 speed gearbox, but the TLR only makes about 12hp compared to 19hp with the XR.
    However the TLR engine makes the same torque as the XR engine, but at much lower revs. This makes it a nice engine for climbing hills etc, like the TLR was intended to do!!
    The pulse generator in the TLR engine is located in the flywheel cover, so the two wires should come out of the flywheel area rather than the side of the head like your original engine.
    The TLR uses a very small carb, to go with the very small valves and inlet side of the head. So your 200s carb will be a bit of an upgrade
    Jason
    Jul 2006
    iowa
    451
    oh ok thats good to know the the pulse generator won't be an issue. If I'm not satisfied with the power I might experiment with my 200s head on the motor, or possibly be on the lookout for an xr200 head, valves, and cam.
    Jason T's Avatar
    UK
    341
    The TLR engine will have more torque than your 200s engine, and the power will be similar as well.
    If you want XR power you will need to change the head,cam,piston and carb.
    Jason
    Jul 2006
    iowa
    451
    well, when i got home from school today the motor was finally here. 2 hours later I had new rear axle bearings in and the motor bolted in.
    Attached Thumbnails Attached Thumbnails 100_0738.jpg   100_0740.jpg   100_0739.jpg   100_0741.jpg   100_0742.jpg   100_0743.jpg
    Jul 2006
    iowa
    451
    i ran out of time to work on it tonight, i still have to hook up the wiring, exhaust, clutch cable, chain, and figure out a kicker. that should be about all it needs.
    Jul 2006
    iowa
    451
    well i did some more work on it tonight. i got the wiring hooked up and it has good spark now. I put a clutch cable on and got the chain and exhaust figured out too.
    The kicker seems like it might cause a little bit of a problem, all i could find for a kicker laying around was from an old CB motorcyle and it hits the rear tire when I try to kick it. I'm not sure if its because its longer than a stock kicker, but the kicker would have to be quite a bit shorter in order to clear it. Is there anyway I could could use parts from a 200x motor and easily convert it to a forward kicker?
    Jun 2002
    Mississippi
    2,552
    you can convert it but you will have to split the case. I would sell that and get a 200x engine. way easier.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Jul 2006
    iowa
    451
    Would I need to really dig into it and switch alot of parts over from a 200x bottom end, or would I be able to get at everything I need by taking off the right side crankcase cover, and then slapping on a 200x right side cover and kicker internals? I would really like to use this engine if I can. Howbout adapting my 200s pullstart to the left side?(just thinking out loud)
    Jun 2002
    Mississippi
    2,552
    you would have to split the center case to use teh 200x kicker. I really do not see why you would prefer that engine over a 200x. stock VS stock, the 200x would spank that engine in every way.
    83 ATC70
    85 ATC70
    86 500r
    Lots of parts
    My 500R
    Jul 2006
    iowa
    451
    ok, that ideas probably out then. I know a 200x would be alot better choice, but the tlr is what Iv'e got and i doubt i could sell it and get a 200x motor without losing a good amount of money. Although the extra power would be nice, I doubt I need it in this hard tail.
