Results 1 to 13 of 13
Thread: 350X chain and sprocket questions
    Back in Happy Valley
    833
    I was wondering where you guys get the fittings for the ends of the braided brake hoses, and what size chain i will need for +3 swinger and a stock gear set-up. Also where's the best place to buy the chain/sprocket sets from. I'm going to go all new with them since its already apart anyway. Thanks for you help, and things like part #'s or a specific link count for the chain would be great because i really dont know how that stuff works, TC...
    833
    Was this a dumb question or something? Has anyone bought the sprockets/chain lot on ebay? I was wondering if they are decent quality or if somewhere like dennis kirk would be a better place to look? Any help would be appreciated, TC...
    na
    5,702
    By the fittings,you must be talking about the banjo bolts????
    Those usually come with the line,but if not many times your original bolts can be used.Or even other machines will work.Banshee 400ex etc.Make sure you also get the brass washers.Each bolt needs 2 of them.
    I have no input on the chain and sprockets,other than buy a good kit with a o-ring chain form Denis Kirk or someone.Get a chain with the longest links available,and cut it to fit you application.
    Make sure you are specific on the year of your 350x.The rear took different sprockets between 85 and 86.
    Proudly NOT a member of
    "Team on the Teat"
    It's a 350X - get an O or X ring chain - the engine can take the added resistance. I like Sunstar and other brand name sprockets, not an EBAY no namer.... Expect to pay over 100$ for a good quality set.
    I run 20" tires so I upped the front sprocket one tooth for more speed and it helped out some. 22" with a stock engine probably suit stock sprockets best.
    I am running a 400EX carb, 450R exhaust, increased jetting and an open AB lid.....
    I will either drop the rear 2 or 3 teeth or try to stuff a 15 in the front as it still has more to go. I think it will rub the case guard so I'll probably drop the rear.
    833
    Thanks for the help i'll get on their website and place an order, the 'fittings' i was talking about on the brake lines are the actual hose ends that the bolt goes through, because i read another post about people having them made out of braided lines at local street rod shops. Thanks again guys...
    PA
    3,515
    a 15 will fit but you cant run the case guard at all
    WWW.HREATV.COM
    Oct 2007
    Grosse Tete, LA
    3,440
    can you trim the sprocket guard to make it fit? I'm thinking of running a 15/38. would that work?
    Quote Originally Posted by The Goat View Post
    I'm running a 14 and it is real close, I think with 15 you'll have nothing left to save the motor if you throw the chain..
    You may be happy with 14 - 37, I'm at 14 - 40 (only cuz the sprock is new) and it needs more but I'm running 20" tires too, not sure if you can buy 36 but I know there are companies that will make whatever you want.
    Are you gonna run 20's or 22's??
    PA
    3,515
    dirtcrasher is right....you cant run the guard at all with a 15
    you need to trim it for a 14.... or have a old worn gaurd
    WWW.HREATV.COM
    Oct 2007
    Grosse Tete, LA
    3,440
    20 inch tires for now. it's looking like all i can find is a 14...anyone know where I can get a smaller rear?
    the 350x has more than enough torque for me, i don't race, so cruising at 50ish would be nice.
    Mar 2007
    lakeville ma
    605
    sprocketspecialtys.com or how ever u spelll it they make any thing u want
    NO 3 WHEELERS CURRENTLY SOLD THEM ALL
    02 GSXR 240 kit STRECHED
    03 BANSHEE 421 CUB
    07 LTR 450
    08 RZR
    05 f7
    07 KLX 110
    670 ho skidoo powered banshee
    1985 nacs kx 80 race quad
    A 13 - 40 with 20" tires will get ya 50mph no problem, a 14 a bit faster.
    Deathman has posted a few times where he gets the custom sprockets but I don't think you need them................
    PA
    3,515
    just a hint for 350x front sprockets.....i use sun star 250r front sprockets on my 350x
    they are double thick ( helps save the splines) and the ones i got had the 2 threaded holes in them for the mounting clip
    pretty sure thats how we got 15t fronts
    WWW.HREATV.COM
