The old Honda Odyssey used the same bolt pattern (3x100). Another member and I went in on a pair of new ones that were being ebayed, he sold his yami and mine is still in the shed. The stock Odyssey uses a 5x8 rim but the aftermarket one is 5x10. The holes will need to be drilled out slightly and a spacer with new studs will need to be used as the rim is offset.
Looks like the seller has another set.... http://cgi.ebay.com/ebaymotors/10-di...spagenameZWDVW
You can probably swap out the front hub/rim from the Tri-Z, I have seen a picture of a YT with a 200x front hub/rim but don't know if there is mod work needed.
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
