well i need to know how to do it, i just sandblasted my side engine cases and i want to polish them along with my forks and triple tee, so how do i go about doing it, thanks a bunch, tim.
1982 yamaha rx50.
2001 murray minibike with 5hp.
fully modded goped.
250cc 4 stroke shifter kart in the process.
i want to know how too..... i did the same thing
famous words "is it wrong to wear my helmet sitting on the toilet and twisting the toilet paper roll like its a throttle while making engine noises?"
yeah i see everyone doing it and it looks so good.
1982 yamaha rx50.
fully modded goped.
search polishing cases on the boards here. here one, see rally4x4racer's post on this thread: http://3wheelerworldforums.com/showthread.php?t=75157
My Rides
1983 ATC200 - U-Haul edition - great mudder - SOLD
1984 ATC200X - sucked a valve - frame up resto & engine rebuild with performance parts in the works
1987 Suzuki DR200
199? Go-ped Sport
ok thanks man
1982 yamaha rx50.
fully modded goped.
Eastwood has some stuff that works good on raw stuff.
1981 250R
1985 200X
1992 Lark Trike!
Lots, and LOTS of sanding first to get the material to a smooth surface, and then you polish. I start with 150 if needed to get rough surfaces down, then 220, 400, 600, and then finish with 1500 before even beginning to think about polishing. I don't recall the exact numbers of the grit, but something close to this.
with a buffing wheel from eastwood on a bench grinder you can stop at 400 grit
WWW.HREATV.COM
ok thanks guys im gonna go get some sandpaper today, i guess ill start with 150, then go up. tim
1982 yamaha rx50.
fully modded goped.
