does anyone know where i can get the wrench to tighten the chain on my 84 r for a reasonable price?
theand screwdriver method is going to break off the teeth soon, and i dont want to be fixin it.
If thats like the 86 (is it?) then shouldnt need a. If it turns hard, the carrier/swingarm might be rusted or full of dirt. I just loosen the clamps and use pliers handles- no force needed.
I remember finding a spanner wrench for my 85 R at www.cachehy.com once.
A few wheelers, + an
'73 Honda 49cc Mini Trail
'85 200 Big WHEEL
"Despite the cost of living, its still popular."
ok, i found the list of stuff, which one would i need?
http://www.cachehy.com/fiche_section_detail.asp
i dont know, i cant go look at it :/. i would venture to say no.
but one of those 2 spanner wrenches is what i need, correct?
I'm sorry, your link didn't take me to any specific parts....??
I'm not sure what size wrench (mm's) the chain adjuster requires. And I don't know if the 84's are different sizes than the 85's.
I was only able to find a spanner wrench for the shock preloads, not the chain adjuster. I was hopin the preload ring would be the same size as the chain adjuster, then you would only have to buy one wrench for both.
http://www.cachehy.com/eshopprod_cat...OCK_WRENCH.htm
'85 200 Big WHEEL
I baught the Motion Pro shock spanner wrench and opened up the large end a little bit to accomadate the carrier. It worked really well on my 83 250R. OH and themethod is why i have a new carrier
the guy i baught it from used a drift and a large
.....i had no teeth left
here is the spanner i baught
http://www.motionpro.com/motorcycle/..._shock_wrench/
STEALTHDUNER
Trikes I Own
1983 ATC300R (Stealthy)
1986 ATC250R (ESR310)Twin))
1986 ATC250R (Stocker)
1985 ATC200X (Racer X)
1985 ATC350X (Thumper)
1984 ALT50
1986 TRX250R (ESR310 PV)
1988 TRX250R
1997 Yamaha Banshee
2004 TRX450R
Ya, thats the one I was thinking of, havent tried it out yet though.
Basically you want a hook spanner wrench, but what size? I don't know.
Sears has some nice ones too, but like I said, never bought one and tried it.
I'm probably going to order the double sided motion pro one, along with just the little single side 3/8 inch spanner wrench for the shock since its such a tight fit, and I can put my 3/8 inch ratchet on there to adjust the preload.
Sears:
http://www.sears.com/shc/s/search_10...0070515x00001b
Heres the 3/8 one I was talkin about.
http://www.cachehy.com/eshopprod_cat...NER_WRENCH.htm
And also one for the axle:
http://www.cachehy.com/eshopprod_cat...DA_ATC_AXL.htm
'85 200 Big WHEEL
