Results 1 to 11 of 11
Thread: US90 with froze up motor
    Aug 2004
    Nampa, Idaho
    1,245
    I may be getting a US90 that has a froze up motor. What are some methods I can use to try to unfreeze it? I have no idea how long it has sat or why the motor is seized up.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Spray wd-40 in the cylinder and let it set.
    Aug 2004
    Nampa, Idaho
    1,245
    Should I put the motor so the cylinder is vertical so it soaks all the way around?
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Quote Originally Posted by firehart View Post
    Ya that would help as well.You can also use a heat gun to get the head warm this may help loosen it up quicker.
    Jul 2006
    pb blaster will work better than wd
    DarkestGKnight's Avatar
    DarkestGKnight is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Babylon
    448
    i like to put oil in the cylinder just regular motor oil works good for me.
    1982 yamaha rx50.
    2001 murray minibike with 5hp.
    fully modded goped.
    250cc 4 stroke shifter kart in the process.
    Dec 2002
    deer park, texas
    2,336
    Aerokroil is by far the best for this.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Well i like to take my right hand and rip the frikin head right off the biatch..that's how i roll.
    Quote Originally Posted by barry_mann View Post
    YES, very good stuff!!
    Mystery oil works great too. I'd stand it on it's end.
    If it has sat, check the airbox for mice and the carb for mice house garbage.
    Even if it frees up, usually rust sticks the rings and everything needs to gone through anyhow. But, at least you can get the cylinder off.
    Aug 2004
    Nampa, Idaho
    1,245
    It needs rear tires too. What are my options there?
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Round,with air...
    The hubs are 3/100 bolt pattern so you are limited there.AMS makes steel rims for your trike.You could use stock rims.
    Tires 18x11x9 20x11x8 22x11x8
    23x11x8 maybe 24x11x8.
