Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 88
Thread: ~*~Alright, Here It Goes! My FIRST Restore~*~ Update Pg. 5
    rckstrgrl21 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    Carlsbad, Ca
    235
    Here is an update!
    After about 2 hours here is what I have accomplished:
    Removed:
    *Grab bar
    *Gas Tank
    *Carb
    *Foot Pegs
    *Air box
    *Exhaust
    *alternator
    And disconnected:
    *Clutch
    *Rear brake pedal
    More to come!
    I cant figure out how to get the nuts on the clutch cover off? What size bolt are they?
    Every screw/nut/bolt is so rusted on this thing, its amazing.
    1985 Honda 200x
    ~K&N Airfilter
    ~Cobra Exhaust
    ~Holeshot Wheels
    ~Re-Jetted Carb.
    Columbia
    5,131
    Do you have a manual?
    has a link, throw him a couple of bucks and download one! You will thank yourself in the longrun.
    Aug 2004
    Phoenix
    1,227
    The clutch cover bolts are 8mm.. If you are trying to remove the engine you do not need to pull the clutch cover off. I wouldn't take it off unless the clutch needed replacing or something else was broken.
    4 Strokes are NOT the wave of the future!
    Nov 2007
    Carlsbad, Ca
    235
    Oops....The drive sprocket cover...NOT the clutch cover. Sorry 3Razors I got them mixed up.
    What size bolts are on the Drive Sprocket Cover?
    1985 Honda 200x
    ~K&N Airfilter
    ~Cobra Exhaust
    ~Holeshot Wheels
    ~Re-Jetted Carb.
    Jul 2006
    western ny
    3,366
    they are metric for sure. probably 10mm. its a common size. if its not 10mm id try 12mm. give me a few min and ill look.
    GIT IT RAAAGGGGG !!!!
    Sep 2007
    British Columbia, Canada
    818
    I think they're 8mm, but I could be wrong.
    [b]'83 200X-
    White/Blue:
    The 2 stroke 200X
    Vids:http://youtube.com/watch?v=HwDqUVM9jOo
    Apr 2006
    PA
    1,464
    Almost positive they're 8mm.
    Jul 2006
    western ny
    3,366
    Quote Originally Posted by TwoHundredEx View Post
    nop you are correct. i looked them up and they are 8mm.
    Nov 2007
    Carlsbad, Ca
    235
    Thanks guys!
    My wrench/socket set only goes down to 10mm. I guess I am on pause until tom. when the parts store opens again.
    1985 Honda 200x
    ~K&N Airfilter
    ~Cobra Exhaust
    ~Holeshot Wheels
    ~Re-Jetted Carb.
    McDerry is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Maine
    440
    5/16 is the same size if you have a standard set kicking about.
    Jul 2006
    western ny
    3,366
    Quote Originally Posted by McDerry View Post
    thats true. but the 5/16 has some slop when you put it on. she said that there was allot of rust. i wouldnt risk rounding the bolts off.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Quote Originally Posted by 84honda200s View Post
    Bolt police is on the scene....Put that 5/16th down and back away from the metric 8mm rusty bolt.Do not attempt to use a 12 point 5/16 socket.
    Jul 2006
    western ny
    3,366
    Quote Originally Posted by edog View Post
    how did i know you would do that ?? naw but for real ive done it. it sucks trying to get a rounded rusted up bolt out.
    Nov 2007
    Carlsbad, Ca
    235
    yay! thanks McDerry! I did have a 5/16 and i got the top bolt off but the bottom one is stuborn and not even inching!
    And it looks like there is a bolt that is recest so looks like i need a socket?
    or is the bottom bolt the only one left to remove the cover? will wd-40 on it loosen it up? I am afraid of stripping it, as I am clueless on what to do if it gets stripped.
    1985 Honda 200x
    ~K&N Airfilter
    ~Cobra Exhaust
    ~Holeshot Wheels
    ~Re-Jetted Carb.
  15. #30
    Nov 2007
    Carlsbad, Ca
    235
    Ok mr. Edog...So how do I get that bolt out without an 8mm, 5/16 or socket?
    1985 Honda 200x
    ~K&N Airfilter
    ~Cobra Exhaust
    ~Holeshot Wheels
    ~Re-Jetted Carb.
