Actually, the scenario depicted by TwoHundredEX is both correct and incorrect at the same time. The only way the conveyor will move in the opposite direction is if the wheels produce a
rotational moment. This is assuming the conveyor is unpowered. Newton's Third Law of Motion: For every action, there is an equal and opposite reaction. The only appreciable force is applied to the airframe of the plane, which causes the plane to move forward. If the wheels provided a rotational moment, the belt would react by moving in the opposite direction. The wheels of an airplane are
not driven by any force, therefore, they cannot deliver any rotational force to the surface below them. Rolling resistance is the only force seen between the wheel and ground. This rolling resistance, in a perfect scenario, would actually cause the belt to move
in the same direction as the airplane, but at a slower rate due to the difference in friction between the belt and the conveyor and the airplane and the air. Confused yet?
Do this experiment if you can. Find a conveyor with rollers instead of a rubber belt. The rollers make it much easier to do this because you won't be able to produce enough force manually to overcome the friction of a rubber belt. Take a bicycle and roll it across the conveyor, increasing speed with distance traveled,
without using the pedals. This simulates the force the engines inflict on the plane and its resultant acceleration. Remember, no force goes to the wheels. Guess what? The rollers will roll in the same direction as the bike, but at a slower rate. Amazing, huh?
Now what Billy is talking about actually would happen. If an airplane is on a conveyor belt that can accelerate fast enough to keep the airplane relatively still, the airplane will not take off, no matter how much throttle is applied. The thing to remember here is that the belt is powered by an outside source and
is not driven by the airplane. Airplanes only take off when the relative wind across their wings is enough to produce a resultant lift greater than the weight of the airplane. If the airplane doesn't move fast enough relative to the air it is passing through, the wings will never produce the force necessary for flight. The wheels might be spinning at 100 knots, but if the wings are only moving 5 knots and the minimum takeoff speed (V
1) is 75, the plane will not leave the ground.
Now are you confused?
