Results 1 to 15 of 18
Thread: Quadracer goes racing-----race pics added 1/30/08
    Sep 2006
    Shreveport, Louisiana
    888
    Well after 2 busy months getting the Quadracer I bought from Lomax ready to race, I ran the ATVCCS season opener at 9 o'clock this morning. There were 7 other riders in my class and 65 total in my race program. The track was 6.3 miles of mostly open field with about a mile of knarly, tight, godforesaken muddy, rutted, whopped-out woods. I practiced on the track yesterday, on the original track of 9.3 miles. Much of the woods portion became so rutted and muddy that it was practically impassable for anything but the utility quad racers. I got stuck 5 times on my last practice lap yesterday, high-centered on all of them, and I'm running 20 inch Pirelli Race Rail XCs on the rear, normally a very good tire. The ruts just got too deep. Basically it everyone would stack up at the bogs, 4 to 8 or so of us, we'd all pitch in to get everybody through and going and stack up again at the next bog. At the riders meeting this morning, the organizers said they had rerouted the track and cut-out most of the woods. I rode the track once this morning to check the new layout and it was passable, at least before the race started. I lined-up on my starting line about 20 minutes prior to the race and as the other racers began to fill-in I noticed I had the only 2-stroke in the field, and there were only two other kick starters. All the other riders in my class were electric start so I knew I wouldn't get the holeshot since it is a dead-engine start, but it fired up on the first kick and I wasn't more than two lengths behind the trail rider off the line. Then about 100 yards off the line, with me still 2 to 3 lengths back and setting up for the first turn, a sweeping right hander to a 200 yard up hill run, a dip-*Edited**Edited**Edited**Edited* on a KTM to my right front brakes too soon and pulls across the front on my Quadracer and clips the right front tire bending the right tie rod and screwing up the toe on the right side. Luckily it didn't end the race for me, but the steering was damed squirrely at speed turning in to high-speed corners after that. I did manage to finish the race on the same lap as the leader, but last in my class, nearly 8 minutes off the leaders time for a 60 minute race. I had hoped for better in the season opener, but it wasn't to be. I just couldn't get comfortable with the steering at high speed and on turn-in it pushed like a Mack truck and wouldn't set and turn through the corner. I'll have to get the front end fixed, hopefully I can just bend the tie rod straight, but it is aluminum. I put a set of Full Flight +2 a-arms on and the tie rods are aluminum. I'm thinking on calling Full Flight to see if they have any chrome-moly tie rods, aluminum bends too easily. To make matters worse, I guess, I cliped several trees in the woods with the front end. Several places were only 3 to 4 inches wider than my quad and very rough and if you didn't slow down and came it hot and bouncing, well you know what happens.
    So at the end of the day I have no bragging rights other than I limped a damaged and poor steering quad to the end of the race. I will say though that I was impressed with the ability of the old 250 2-stroke to hand with new 400s, 450s and even an Outlaw 525. I wasn't giving up much in the way of horsepower to the new bikes. I did have trouble getting it in the right gear sometimes coming out of corners and the torquey thumpers would pull out on me untill the 250 hit it's powerband. The thumper guys weren't shifting nearly as much as I was. I don't have huge time on the seat of my Quadracer so I know I'll get all the bugs worked out and be more competitive before the season gets too far along, hopefully by the time warm weather gets here.
    I didn't take any pictures, but I will post a link to pics when the ATVCCS sends me one and to the race report when it is written.
    Chris
    >>>>>>>>>>>>>>>2007 Yamaha Raptor 700R>>>Cross Country Racer<<<<<<<<<<<<<<
    www.myspace.com/bluelionracing
    Support my 2009 sponsor:
    For all your ATV suspension needs.
    Jun 2004
    Pyeongtaek, South Korea
    474
    The main thing is that you and your machine survived and finished. Attrition is the major killer in CC racing. Get some chromoly tie-rods and it will be much more durable, because as any racer knows, it's not if contact happens, it's when.
    Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
    The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
    "To err is human, to err continuously is liberal." - Me
    Sep 2006
    888
    I hear you on attrition, I passed maybe 5 to 6 riders pulled off and sitting on their dead quads with a stupid, frustrated look on their faces.
    I forgot one thing. My rear brakes fadded badly during the race too. When I bought it, I changed fluid to a DOT 4 race fluid and flushed the lines, front and rear and put on sintered bronze pads, thought I'd be okay. About half-way through or so the rears got to where they weren't a reliable stop into corners by themselves and wouldn't really lock the rear tires. I had to start feathering in front brake into the corners, which made the twitch, pushy frontend worse and that's not my normal riding style to boot.
    Nov 2006
    southern oregon
    2,338
    COngrats on finishing your first race... It definately sounds like you had a good time
    Quote Originally Posted by ccdhowell View Post
    You may consider going back to stock... IMO +2" arms are disadvantage in nearly all non-MX situations... width is over-rated...
    CLutch, Clutch, and CLutch... it works everytime...
    2-stroke lover
    Sep 2006
    888
    cr480, I've gotten used to shifting my Tecate without the clutch and the QR doesn't like it that way. I'm forgeting to clutch when the heat is on.
    Oct 2005
    saratoga, ny
    2,819
    well at least you gained experience chris and had some fun doing it. the quad may be a bit beat up, but, its fixable and will be back for the next one!! good luck thru out the season man!
    Sep 2006
    888
    Pics of the aftermath, taken in my garage this evening. Washed it after I snapped these.
    Chris
    Sep 2006
    888
    Race photos
    The ATVCCS use Snapfish photo service. They just posted the race pics from this weekend...here's some of me, don't be too harsh.
    Chris
    Jun 2004
    474
    So is that the guy who caused the damage on the KTM?
    Sep 2006
    888
    Yep, that be him.
    Newfoundland
    5,280
    Pics look great!
    Dec 2002
    Kansas
    2,387
    Looks great, looks like you had lots of fun. When is the next race?
    I had the RIGHT to remain silent, I didn't have the ability!
    Sep 2006
    888
    Feb 17 in Graham, Texas. It's quite a haul for me, little over 5 hours, but looks like I'll be able to make it.
    Oct 2005
    saratoga, ny
    2,819
    sweet ...any write ups on it?
    Sep 2006
    888
    No write-ups yet, just checked, I'm looking for them too. They'll get posted soon I'm thinking and I'll get a link up if it's a favorable write-up for me.
    Chris
