I have a NICE 85 brake guide and some fork caps from a bike that i just parted out. PM me if interested.
My old 1985 250R http://www.flickr.com/photos/24898661@N07/show/
Feedback http://www.3wheelerworldforums.com/s...feed+back+edog
Currently trikeless
You better stop running those bars. The bend is before the end edges of the bar clamps and it scores the top of those aluminum bars. Then on a good jump someday they'll snap right off. I've seen it happen!!
Currently trikeless
< Look at the pics, you'll figure it out....
I'm going to swap those bar's when i find a set with the right space between the mounts. Their just what the bike came with.
I made another wire, with more success, nearly there. But i need to get some more wire before i make an 85 one (only had a short bit left). Also i'v played with making a mounting bracket/plate of the 85 style. Not perfect and no pic's yet, but i think i have a simple way to form them nowi hope.
198? Manco Quester 300
1983 KLT 200
1984 Tri-Zinger 60
1985 ATC 70
1985 TRI-Z
1985 TRI-Z (two Wheel)
1985 ATC 250R
1985.5 TRI-Z
1986 TRI-Z (quad)
1986 Tecate
1987 Malaguti Ranocchio 50
2001 YZ 250
Nice work. You planning on making those available to other members? I'd buy a couple.
If you could make a 85 with a 86 mounting bracket I would be all over it!!!!
Currently trikeless
For an 86 with 85 wire, Glamis has an 86 350X guide (same ?) item # 270134746789 , i'll make a new wire for it and send it to you if youre real keen ?
If these 85's are any good i'll make a few to sell. But if it looks shite i won't !!
I'v looked at the 86 part and i'll have a go at it. But it will be much thinner material.
I need to get to the builders for some thick steel to make a former for the 85's, so they all come out the same (and right) so i may be another week before i get a good bracket that can be mass made.
As for the wire guide, i'll do them as soon as the wire is available on monday![]()
1983 KLT 200
1984 Tri-Zinger 60
1985 ATC 70
1985 TRI-Z
1985 ATC 250R
1985.5 TRI-Z
1986 TRI-Z (quad)
1986 Tecate
2001 YZ 250
Right, because i had one, i had a go at the 86 first. Not a bad first attempt![]()
And on the bike with a wire guide, it looks a little better. This was relatively easy to make.
The 85 part though was a totally different story. I will not be making another one, it's nearly impossible to bend the metal to form the sides holding the wire. It beat me in the end.
Over all, not a wasted project but the 85 is far beyond my skill. I'll make another 86 out of some thicker material (original was 3m ) . Heres the final pic's side by side. The 85 is crap![]()
1983 KLT 200
1984 Tri-Zinger 60
1985 ATC 70
1985 TRI-Z
1985 ATC 250R
1985.5 TRI-Z
1986 TRI-Z (quad)
1986 Tecate
2001 YZ 250
Thats the thing, it only needs to be functional.
Anyone who performs a real "restore" will insist on a NOS OEM part.
But for you, me and the rest of us, ANYTHING that works is better than nothing.
A crude tool and die is all you need to get them all looking the same.
Pardon my French, but the 85 was too much of a tawt to bother with again. It takes too long to form. The 86, although the more complex design, was much easier to make. I was 6 hrs just on these two parts. And i doubt i could work any faster on the 85's.
86's, no problem. I could turn out 12 in a good half day if i did a batch. Just seems too much work and too long time to sell them for what their worth, which isnt much.
1983 KLT 200
1984 Tri-Zinger 60
1985 ATC 70
1985 TRI-Z
1985 ATC 250R
1985.5 TRI-Z
1986 TRI-Z (quad)
1986 Tecate
2001 YZ 250
why not buy one off of a dirt bike if you do not want an original?
