Results 1 to 8 of 8
Thread: A Couple Questions About 250R - Tri-Z Swinarms
    Sep 2006
    canyon country CA
    47
    Hello
    Will a 86 250R swing-arm and carrier work on a 85 250R ? .. 2nd question are the 85 and 86 Tri-z swing-arms exactly the same . i ask because i have a swing-arm that i was told came off a 85 tri-z however it looks quite a bit different then the OEM swinger that is on my 85 triz at the moment so i am wondering if both years used the exact same or did the design change in 86 ?
    Thanks in advance for any help you guys can give me
    Phoenix, AZ.
    6,719
    Not sure if the 85 R axle will work with the 86 carrier but I know the rear brake hardware is different. As far as I've heard you pretty much have to change the whole rear end to make that swap work right. I would think some parts would swap though (rotor hub for example looks the same to me).
    The 85 and 86 Z swingers are interchangeable but they are designed differently. The 85 is actually stronger. Only thing you have to change with that swap is the pivot bearings.
    Sep 2006
    canyon country CA
    47
    Thank You !!
    Jackson MI
    1,688
    The 85R axle won't fit the 86 carrier, but a 86-89 250r axle will fit an 85 carrier.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    also the linkage bushing are diffrent sizes in the Z
    na
    5,702
    Mr.Hall
    Can you enlighten me on the trx axle fitting the 85 carrier???
    My friend has a lonestar in his 85 and he said it went right in.
    I have a RPM dominator out of a 86TRX,that I wanted to put in my 85,but when I sized them up,it looked like I had to too much axle area.Did I just overlook something?
    Do they just go right in,with no mods or spacers?
    Gameover,I am pretty sure you can use your 85 rear brake caliper on the 86 R swingarm,but you have to use the 86 break caliper bracket.The calipers are the same.
    Proudly NOT a member of
    "Team on the Teat"
    Jackson MI
    1,688
    Mosh, the only difference Is the sprocket hub offset Is different. The 86-89 axle will fit the 85 carrier and the chain will line up PERFECT. The gap between the carrier and spocket will be wider though. The offset part of the sprocket hub Is on the Inside (toward's the carrier) on the 85. The offset part of the 86 Is on the outside.
    I got the piston In the mail on friday also.
    Jason.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    na
    5,702
    Sweeet!I see a purty chrome RPM in the Hall powered 250r next weekend .Thanks man!Calling you in a few need more work done.
    "Team on the Teat"
