I found a 200x trike today. But I do beleive it has a 200m motor in it . Will this work? Everything looks ok. Of course I didn't hear it run. Chain was not hooked up. What would just the roller be worth?
Sounds like an Auto-X. It'll work fine, quite a few people have done it.
Not sure what it would be worth as a roller, need to know more about it first.
Condition of the plastics, frame, tires/wheels, etc.
im pretty sure the 200m and 200e engines bolt right into the 200x frame
83 Yamaha 225DX
84 Yamaha 225DX
84 Honda 200s
78 Kawasaki 175 enduro
83 Susuki LT250
02 Bombardier Traxter
The 200S engine bolts in, but the M engine won't because of the electric starter in front of the cylinder. If you use an M engine, you have to either notch or dimple the downtube for clearance. I'm not sure if the E engine will fit in a 200X because the low-range transmission on the output shaft looks like it won't clear the chassis. If the trike you found has a pull starter and no electric starter, it has a 200S engine.
Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
"To err is human, to err continuously is liberal." - Me
83 Yamaha 225DX
84 Yamaha 225DX
84 Honda 200s
83 Susuki LT250
What part of texas are you located?
Never argue with an idiot. They will bring you down to their level and beat you with experience.
Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
1981 Wife ( Project)
North Texas
I'm currently doin a rebuild on a 85 200M and was lookin to put it on a 86 200X. Honda says that the 200m engine will fit most 82-85 models but not an 86 200X. I bought a new wiseco piston but the 200x takes a differant one, does anyone know if that 200M motor will work? or could i just replace the jug from the 200M onto the 200X? Any help is appreciated.
The 86/87 200x is not nearly the same as the 83-85 200x. I don't know if the pistons interchange. (TRX200sx engines may bolt in, but auto clutch and electric starter. Starter may hit frame, but it does have reverse on the chain drive SX engine)
And 86 200x is worth decent money relative to an earlier model. Even to part it out as parts are hard to find. I'd keep the M as it is, and rebuild the X if possible.
__________________________________________________ ________________________
To the original poster, I think I saw one that was seized in a scrap yard for ATV's. The downtube must be bent to clear starter motor, like all 350x frames seem to be from the exhaust hitting the downtube.
If it's in GREAT shape with no cracked fenders, no rust or anything, could be a $450-$600 trike. That's if it's great, tires, exhaust, brakes all work, seat cover, etc.
I've picked up beater 200x's for around 150 before. So it really depends on condition.
And you should be able to hear it run without a chain, just not be able to ride it. But yes, it should work.
Have bought 3 200x's and have one built as an auto-x (with an 82' atc 200 motor in it). 1983' 200x: $250. 84': $400. 85': $200. All running (one was for parts so is not a trike anymore). Was going to upload some pictures to help you, but computer won't allow it at this time. So a roller isn't worth all to much.
I put a M motor in an '85 frame once. Notched out the frame then reinforced it on both sides. Made a battery box behind the airbox. Worked pretty good!! A lot smoother to ride than the M.
ok so to put a 200 auto with a starter you will have to cute the down tube to clear the starter?
1984 110 project
1984 125 parts bike
1983 honda 200x
19 85x2honda 200x
1985 honda 250sx
1985 honda 250es
I bought a 200s engine off of Ebay for my 200x. Looks like I'm going to turn it into an autox. Only cost me $170 and the guy says it runs. It looks clean except for the valve cover gasket looks like it leaks. But that an easy fix.
