Results 1 to 10 of 10
Thread: how to straighten forks
    Jun 2002
    Mississippi
    2,552
    Smile how to straighten forks
    ok i need some ideas on how to straighten some forks. i thought about chaining the rear to one tree with a come along on the front tire to another tree
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    scrawny's Avatar
    scrawny is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    WI
    181
    what kind of forks?
    thanks for the sig
    sponsorhouse.com profile: http://sponsorhouse.loopd.com/Member...er65/Home.aspx
    Jul 2006
    iowa
    451
    i would definately find a shop or a buddy with a hydraulic press. just put the fork in a set of v blocks and pump away.
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    Press and v blocks with a dial indicator would be my suggestion
    You could also put it in a lathe, hold it with the tail stock and bend it back into shape....
    Howdy's Avatar
    Celina, Ohio
    10,079
    V blocks and a press is what I use. You might try a local machinest and see if they can do it as well. before I got my press the one local place straighten 3 forks for $25 for all 3 ( but that was 9 years ago ).
    Howdy
    Mar 2005
    overton, PA
    5,257
    i was gonan say if i still had axcess to a 45 ton press i woudl say send them up and i woudl do them for ya but i have always used a pressand v blocks and then chuck them in a lathe to check the runout
    Piece of cake.....
    You need 3 v blocks, a press, some patience (beer) and a dial indicator. Or ship them to someone who has all that crap, but send along more beer
    scrawny's Avatar
    Nov 2007
    WI
    181
    thats what i did. dont forget to go past a little ways cause it will spring back a little. good luck!
    thanks for the sig
    Jun 2002
    Mississippi
    2,552
    i have all that. i may give it a shot.
    83 ATC70
    85 ATC70
    86 500r
    Lots of parts
    My 500R
    Quote Originally Posted by 200x Basket View Post
    I'll just say this - I try to keep the supporting blocks about 12"s apart and isolate that bend with a sharpie marker. Otherwise you can end up making an "S" bend. And as Scrawny remembered, you do have to go WAY past the bend to get it right. It springs back bigtime. But, fix a couple forks and you'll gain confidence and feel like an expert
