tell me whats up.... need info...
well i couldnt get the beast going because i flooded her out... so i have another guy pull me to get her started...well she fired right up ran the hell out of her most of the day... but as soon as she cooled off she wouldnt start again but if she stayed hot she fired right up? whats up? i went throught tne carb again and same thing happened again?the plug couldnt be it right?
Thats what a dead igniiton system sounds like. Takes more sparks to fire cold and at low speed. The 250R ignition system doesnt like to fire much below the 1700 RPM idle speed, as I recall it wont fire below 650 revs. . Pull starting cranks it much faster than the kicker can turn it.
Ride it like that and itll blow up.
The other posisbility is that teh carb is flooding badly and fouled a sparkplug, but thats not likely as you said you went through the carb.
ok well i took out the reed cage and cleaned it got a new plug...and checked the carb again... and still nothing ....
im going to due a compression test tomarrow and see what it is...i talked to the shop about it and they didnt have a clue either...anybody???........... thx
//ArrowChat Integreation Code
