Anyone Know Which Engines Fit My Atc?
Does anyone know what engines and engine parts would fit my stock 1980 honda atc 185?
1982 200es engine
1984 200s bottom end
1981 185 engine
1984 200s head
1982 200s engine
1984 200s engine
Thanks for your help A.J.
All of the Honda ATC's from 185 to 200 that have chaindrive. All the engine parts are pretty much interchangeable (you can stick a 200 cylinder and head on a 185 block and crank, etc). Even a first gen 200X motor will bolt in, but you'll need to use a utility trike exhaust.
You might need to modify the frame slightly if you use a 200E motor, the electric start might be in the way.
I'm back in the USSR...
thks red rider saves me alot of time!
//ArrowChat Integreation Code
