Results 1 to 2 of 2
Thread: HELP NEEDED !!! Big Red Engine and Chain REMOVAL
    Dec 2007
    San Antonio
    11
    I have a big red.
    it was smoking real bad, so i ordered a Top end Rebuild from ebay.
    (gaskets, cylinder, pistons, ect..)
    i am trying to remove my engine from the frame.
    i have all the mounting bolts, wires, and everything off and its loose and ready to come out.
    I have repair mainuals, that explain how to disconnect the chain to remove the motor. all the manuals tell me to remove the SPROCKET COVER which is right behind the Pull start casing.
    on my 185s, the sprocket cover looks just like the pictures in the book, and easy to remove.
    But... on my Big Red 200 .. it does not have the same sprocket cover.
    it has the Housing box, where the High and Low gear switch is.
    what is the best way to remove the chain so i can pull my motor out?
    Dec 2006
    Northern IL
    62
    Pop the masterlink off. Put in neutral. Pull the chain out. You'll have to fish it back over the sprocket to put it back together, but it'll be easier than taking it all apart.
    If you want to get at the sprocket you have to remove the hi/lo assembly, Pull start, then the stator plate. Its not that bad, just time consuming. Its in the 200e manual.
    2006 Honda TRX 450ER
    1983 Honda 200e Big Red (sold)
    1986 Honda 350x (sold)
    1982 Honda 200e Big Red (sold)
    1984 Honda ATC 70 (sold)
    1985 Honda ATC 110 (sold)
    1988 Suzuki LT80 Quadsport
