lets say you were setting up some 350x forks for about 300 pounds. what weight fork oil would you use?
I have two sets of 350x forks. one set of springs is made of a larger diameter steel. which set is better for a a 300# rider? can i swap the springs between the forks? one set of forks is bent and I am trying to make the best set.
