*edited my first post*
Ok i have the 350x all apart, and the swingarm itself has the slightly smaller diameter (outside) still on it. Is this part or the end caps i need to take off? Its about 3/8 wide and on the inside i have a metal ring thats holding the bearing in place. Do i need to get that piece with the smaller O.D. off the swingarm, or do i simply press (beat) the bearings out, and those rings inside will come out too?
I dont want to damage my swimarm anymore than i have already trying to figure this out. I looked in the manual and it still doesn't make sense to me. A pic may be nice if theres a trick to it that i'm missing. Thanks TC...
out the opposite one. Use an extension to make sure you have enough to hold onto without busting your hand or the swingarm. I did that like listed above with a piece of round stock that fit just right so i'm sure a socket would do the same. The bearings must be pushed out the side they are installed on, you can't make both come out one side.
come on over and I'll take care of it for you. I have allot of stuff to do tomorrow but maybe I can take care of you while I'm in the shop. PM me your phone number.
