I'd go as close to 50/50 as I could myself.
I can read a plug, but I can't hear pinging on an small motor to save my life.
It's easy to hear an enclosed automobile engine when you lug it up a hill, but not so easy with these small single cylinder engines....
If you are running a stock cam or a well designed mod cam, you're motor will do just fine on 93 with 11:1. I've had a few heavily modded 200X. Don't use additives.
That piston is a an old Helm and Son cast piston. They were 10.5 to 1 compression.
so now its a helm and son?
or is it an aries? thanks.
My Rides
1983 ATC200 - U-Haul edition - great mudder - SOLD
1984 ATC200X - sucked a valve - frame up resto & engine rebuild with performance parts in the works
1987 Suzuki DR200
199? Go-ped Sport
Arias pistons are forged and you will generally see some machining around the gudgeon pin area. Can you see machining because I can't. Its not now a Helm and Son. It always has been.
took a quick look, and cant see any machining that i can pick out.
Were there any specific marks that helm and son put on their pistons?
Where would I look, because I looked all over and the only mark I saw was “0.25” on the top of the piston?
by any chance do they still make them for the 1st gen 200X? thanks guys.
My Rides
1987 Suzuki DR200
199? Go-ped Sport
