Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: what piston is this??? 200X
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by The Goat View Post
    93 should be fine...if you want you could add a little octane boost for peace of mind.
    Should is the key word. 11:1 is right on the edge for an air cooled engine. It wouldn't be too hard to make it ping on 93 and you can toss that additive crap out the door too. Far better off mixing then wasting money on that junk.
    '02 Honda 416ex - A seasoned blend of 11 herbs and spices
    '04 Honda Recon - The yard machine and snow plow
    '88 Honda CR250R - Another chapter in my torrid all terrain affair
    I'd go as close to 50/50 as I could myself.
    I can read a plug, but I can't hear pinging on an small motor to save my life.
    It's easy to hear an enclosed automobile engine when you lug it up a hill, but not so easy with these small single cylinder engines....
    Aug 2007
    Moab, UT
    1,807
    If you are running a stock cam or a well designed mod cam, you're motor will do just fine on 93 with 11:1. I've had a few heavily modded 200X. Don't use additives.
    Feb 2003
    Australia
    927
    That piston is a an old Helm and Son cast piston. They were 10.5 to 1 compression.
    Apr 2007
    Springfield, PA
    889
    so now its a helm and son?
    or is it an aries? thanks.
    My Rides
    1983 ATC200 - U-Haul edition - great mudder - SOLD
    1984 ATC200X - sucked a valve - frame up resto & engine rebuild with performance parts in the works
    1987 Suzuki DR200
    199? Go-ped Sport
    Feb 2003
    Australia
    927
    Arias pistons are forged and you will generally see some machining around the gudgeon pin area. Can you see machining because I can't. Its not now a Helm and Son. It always has been.
    Apr 2007
    Springfield, PA
    889
    took a quick look, and cant see any machining that i can pick out.
    Were there any specific marks that helm and son put on their pistons?
    Where would I look, because I looked all over and the only mark I saw was “0.25” on the top of the piston?
    by any chance do they still make them for the 1st gen 200X? thanks guys.
    My Rides
    1987 Suzuki DR200
    199? Go-ped Sport
