Results 1 to 13 of 13
Thread: Has anyone made a wiring harness?
    Havoxx's Avatar
    Havoxx is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2008
    Miami, FL
    233
    I was wondering, has anyone ever made a wiring harness, I was looking through the diagram and whatnot, and it's an incredibly simple harness, has anyone ever like, remade or rebuilt one for their bikes?
    I mean, it doesn't seem like it would be too difficult, just that my bike has been sitting outside before I got it for oh say, 7-8 years, and in all reality, the wires are probably close to rotting from the inside-out at this point. I also figure before I dish out $60 for a new stator, might as well eliminate this as a culprit.
    Nov 2002
    Kirkville, NY
    3,831
    Check what plugs you will need first, new CDI and stator plugs come to mind as possibly being hard to find.
    The only trike I have made complete harness for is my atc70, It uses 2 wires and no special plugs.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Havoxx's Avatar
    Jan 2008
    Miami, FL
    233
    Yea, I figure I'd need to use the CDI one from the bike the others are just, well, they're called tamiya bullet connectors in the R/C world :P, I'd most likely use power-poles though, since the offer no resistance :P.
    Richland WA
    808
    Yep, the problems is finding the connectors, and they are most of the failures. Ive rebuilt the R harnesses, and designed and made harnesses for industrial machines.
    The copper wire in old harnesses tends to oxidise and become difficult or impossible to solder.
    Then if you find a new CDI plug, the old terminals on the CDi are also worn,.
    Havoxx's Avatar
    Jan 2008
    Miami, FL
    233
    Yea, that's why I was probably gonna use R/C car connectors, they seem to work well for these types of applications, since they are made to run high-heat and in water and whatnot. Something along the lines of these connectors, since they can inter-connect and pair up to make a big connector. http://www3.towerhobbies.com/cgi-bin...&I=LXD176&P=ML
    Jun 2004
    Pyeongtaek, South Korea
    474
    I plan on building my own harness for my KXF326 because I'll be using a PVL ignition system and a Honda 450R killswitch. I'll also be eliminating the lights and key switch. The diagram below is a modified Tecate-4 schematic, which is what I'll be basing mine on.
    Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
    The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
    "To err is human, to err continuously is liberal." - Me
    Jun 2009
    Missouri
    4
    Help please
    I need a wiring harness for a 1979 honda 110 3 wheeler, I want to make it run so bad again,
    How can I build up a set of wiring harness? or buy a used one here?
    anyone?
    Nov 2002
    Kirkville, NY
    3,831
    Do you have the wiring diagram? If not there is one on the main page. It looks like an easy harness to make, I was going to make one for mine. I don't remember it using any special plugs only the common round conectors.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    ilmoakw is offline At The Back Of The Pack Arm chair racerFirst time rider
    moncton
    244
    I built a new harness for my 200S. I used the OEM CDI connector and just soldered/heat shrink all the other wires. The only connector I have is the CDI...
    Dec 2002
    deer park, texas
    2,336
    Harness are easy to make, like stated before just get the plugs for the diffrent electrical componets that require a plug. I prefer to make mine because i use the same color code on everything. then if i have a problem, it is very easy to diagnose. Also you can upsize the wire. Factory harness's usaully use the smallest wire they can get away with.
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    Oct 2007
    Grosse Tete, LA
    3,441
    lol...this reminds me of the lifan harness I made.
    6 hours or so making the harness according to the directions. 1 hour of no spark and testing. 10 minutes of getting pissed off, hacking it up and making something that I knew would work.
    Apr 2004
    Brigham, Québec, Canada
    1,529
    Quote Originally Posted by The Goat View Post
    I'll need you when it will be the time to wire my YTM-225. Wanna came down and help me. I'll pay you a real beer.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Oct 2007
    Grosse Tete, LA
    3,441
    drink up me hearties yo ho
