Results 1 to 8 of 8
Thread: do i need race gas with this?
    Ryan. is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    Michigan
    317
    do i need to run race gas with a weisco 12:1 compression ratio piston for a 350x?
    Well, you didn't mention what ATV, but if you are running 12:1 CR, then you should run either race gas or mix race gas with premium to keep the detonantion down. if not, you will be changing, that 12:1 piston one way or another.
    Feb 2008
    Michigan
    317
    Quote Originally Posted by mdunn View Post
    its a 1985 atc350x
    Aug 2006
    new hampshire
    914
    you need to mix 50 50 for anything over 11:1
    1982 ATC 70
    1983 ATC 200E yard rat
    1984 ATC 200X
    1984 ATC 200S (X2)
    1985 ATC 70 (X2)
    1985 ATC 200S
    1985 ATC 250R
    1986 TRX 70
    1986 ATC 350X
    2004 kfx 700 XC
    2006 prarie 700 XC
    2009 Brute Force 750
    2020 CF Moto 600
    Feb 2008
    Michigan
    317
    Quote Originally Posted by badasskfx View Post
    what do you mean 50 50?
    Fresno Ca
    2,695
    New 450's run 12:1 stock and they recomend 91/preimum. Its not optimum but i have see many people on x's run regular gas on a 12:1 engine. I woudnt recomend it but you can do it and probably not have any problems.
    Aug 2006
    new hampshire
    914
    50% 93 50% race fuel. other wise you will have detnation
    i would not go by what the 450's run.....why do you think they have a fairley high rate of engine failures.
    1982 ATC 70
    1984 ATC 200X
    1984 ATC 200S (X2)
    1985 ATC 70 (X2)
    1985 ATC 200S
    1985 ATC 250R
    1986 TRX 70
    1986 ATC 350X
    2004 kfx 700 XC
    2006 prarie 700 XC
    2020 CF Moto 600
    Aug 2006
    Arlington, Wa
    1,027
    from the mouth of famed engine builder Jack Moore, do a compression test 1st.
    up to 195 = pump fuel or premium
    195- 215 = 50 / 50 pump fuel and 110
    215 and up = straight 110 or higher
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    85' YTM 225DX (sweetie)
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
