Thread: quick question..
    stoney420's Avatar
    stoney420 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Bridgeport, NY
    363
    quick question..
    on my buddys 83 big red (battery is dead) when its idleing the headlight is nice n bright but as soon as he gives it throttle the light dims right down so he cant even see,....... i have the same wheeler but in much better shape, my battery is also dead, but when i give mine gas it gets a little brighter, not dimmer.... anyone know why his gets dim when he hits the gas?
    May 2007
    Coshocton, Ohio
    1,815
    Could it be a bad ground on the light circuit?
    Appalachian American Racing
    the home of
    Sep 2005
    Lipetsk, Russia
    2,824
    My Big Bear does the exact same thing (dims, but not as bad as your friends). I think it's because the machine needs a battery to keep the voltage at a steady level.
    I will try again after putting my new battery in and see if it goes away.
    If it gets dimmer, might possible be something wrong in the charging system? I will have to check it out.
    stoney420's Avatar
    Bridgeport, NY
    363
    yea i think a new battery would clear it up which he needs anyways but would still like to know whats up with it since mine has a dead battery too but doesnt do it.. he did let it sit in his garage for about 3-4 months without riding it but im not sure if that info would help diagnose the problem..
    any ideas?
    ill let yas know if we get it figured out
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    My 82' Big Red does the same thing. There is no battery in it, and the headlight does the same thing, butt worked fine when the battery was good.
    TF 07,08,09,10,11,12,13,14!
