Originally Posted by
whyzee
Unscrew the black caps and let the air out,if any
Unscrew the little bolt at the bottom of each leg to drain the oil
wait 5 min
hold the front brake and push upand down at least 20 x to get the rest of the oil out
Put the bike on a stand so the forks are in the air
unscrew the top of the forks,be ready for the springs to pop up
remove the springs,keep note which end is up, they are tapered
lower the bike so the fork tubes are bottomed out
put the drain bolts back in
fill the forks with 15.5 oz in each leg
put back on stand
put springs back in, tapered end first
put cap back on
Go ride!
If you unscrew the caps first the oil will drain faster and you wont have to pump them 20x . Its like poping the gas can breather!!
3-85 ATC 70
86 ATC 250R
86 WETBIKE
01 KX250
2011 KAW SXR800- 35YR EDITION
05 HERITAGE/SPRINGER/SOFTTAIL
