1986 250r
Well I never realley posted pics of when it was done so here it goes. Its about 98% done just need to get the back breaks working, seat covered and the head rechambered and a little bit of tuning. Here is the list of things done:
Engine: 310 big bore kit, port and polish, 38mm carb, v-force stage 3 reeds, cool head with 19cc dome, K&N filter no airbox, Aluminum exhaust flange, adjustable timing plate, re-worked clutch basket for better oiling and cooling with kevlar clutch setup, 89 250r clutch update, Boost bottle, and full fmf exhaust (soon to have a section exspansion chamber).
Suspension & Brakes: Front fork springs replaced with stiffer progressive springs, NASA adjustable pre-load fork caps (adjusted all the way down for stiffness), CR low bend black aluminum handle bars, 450r rear shock and swingarm, +4 rear axle, dual row bearing carrier, yfz450 front master cylinder with stainless line, front flamed brake rotor (not installed yet), thicker rear brake rotor, and crf450 rear master cylinder with stainless line.
Body & Tires: Carbon fiber front fender and radiatore shrouds (soon to have carbon fiber rear fenders as well), black tank, black rear fenders, aluminum gas cap and shifter, 6-pack rack (for extra fuel can), polished duglas 10" blue lable rims on rear with titan fast trekkers, and titan (forgot the model) front tire on stock but polished front rim.
Well here are the pics ENJOY!
Alex
ATC500AF
looks awsome and sounds fast!
Could you post some Larger Pictures ? ?
How much did the Rims & Tire Combo Cost you ?
Looking good ...
I baught the rims for $40 and polished them up. Then I baught the tires for $78 so about $118
ATC500AF
did you click on the pics?
ATC500AF
Yeah and the pics themselves aren't very big at all. Not much bigger then the thumb you click.
//ArrowChat Integreation Code
