Results 1 to 8 of 8
Thread: TRX Crank question - need answer
    Tionesta, PA
    5,743
    After looking up some part numbers - I see the 1986 TRX250R crank has one part number - and the 1987 - 1989 has a different but common part number.
    What I need to know is - what is the difference.
    Please help me.
    Thanks,
    Tim
    Sep 2006
    Northwest Indiana
    1,893
    86 short rod. 87-89 long rod. 86 trx is the same as 85-86 atc.
    Tionesta, PA
    5,743
    OK guys - so you could put an 86 crank in an 87 bottom end - and vice-a-versa - 87 crank in a 86 bottom end???????
    Basically has nothing to do with crank length.
    Sep 2003
    Elizabethtown PA
    1,581
    you just need the piston to match the style crank your using or use a 87-89 crank with a 86 piston and a spacer plate
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    3leggeddog's Avatar
    Nov 2004
    tim,my motor is a 86 bottom end,with a 89 hotrods crank,with a esr 5mm spacer plate.Makes her a lil stroker motor of sorts.You have to use the 89 piston,with the 89 crank/rod.
    Sep 2006
    Northwest Indiana
    1,893
    Two different piston styles. 85-86 atc trx short rod. 87-89 long rod. Pin to crown height is the difference. Which is the difference in rod length between years.
    Tionesta, PA
    5,743
    thanks guys - all cleared up now!
    Very informative thread
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    Quote Originally Posted by 3leggeddog View Post
    with a long rod and a short rod piston,, you don't have a stroker motor,,, the only way is if the pin location in the crank has been moved,,, so you still have a stock stroke motor,,,,,,,,,,,,,
