Results 1 to 10 of 10
Thread: Will muratic acid strip chrome?
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    So on my old FMF 250R silencer, I'm needing to cut off and weld on a new pipe of larger diameter coming into the actual silencer canister for the 500 motor, but its chromed and I can't (well, I can, but I don't want to try) weld over top of it. If I take the piece and throw it in some muratic will it strip the chrome off or am I gonna have to grind it?
    PA
    3,515
    iv welded over chrome before...you dont even know its there
    in fact i shortened my chrome shifter and had it tiged...... it didnt even discolor
    WWW.HREATV.COM
    Jul 2006
    yea billy you can weld over chrome, its a very thin metal, and really your just welding the metal underneath, ive done this before making custom bumpers, wich reminds me.....seamless 62 continental bumpers......yumm!
    Live Oak, FL
    15,070
    Arent the particle going to burn off and be floating around inthe weld pool though?
    PA
    3,515
    iv only welded chrome shifters and kickers but i never had a weld fail
    WWW.HREATV.COM
    May 2007
    Coshocton, Ohio
    1,815
    Billy you have nothing to worry about. If you use muriatic acid on it the steel under it will also be eaten away to a degree. Are you using a mig welder? If so just go for it.
    Appalachian American Racing
    the home of
    Live Oak, FL
    15,070
    na, Tig. Which is why I was a little worried about the stuff flaking/burning off and going into the weld pool or onto the tungsten and then mucking up the cleanliness of the weld but I suppose its just an exhaust joint and its not extremely imperative.
    hadar's Avatar
    Rock Island IL
    699
    Yeah, tig welding over chrome just dosen't sound good at all. Does chrome pool? I would just tape it and lightly sand it off to be safe. For some reason, I just don't see it pooling good at all. Or if it does, it might contaminate the weld, bigtime.
    Apr 2003
    HARTFORD CT, USA
    478
    no muratic acid will not strip chrome. I would grind the chrome off where you are going to weld its only 0.001" thick.........
    'WHEN IN DOUBT.........GAS IT!'
    87 KXT250B2 Tecate
    86 ATC250ES BIG RED
    85 ATC350X
    85 ATC70
    'A FEW IN PARTS'
    Feb 2008
    Pennsylvania
    2,306
    don't weld over it it will not fuse properly. I weld constantly and it will not adhere properly to the metal. clean the surface first and youn will be fine
