i got a used motoplatt recently for my 250r and need to figur eout how to set the timing i dont know witch set of timing marks is on the flywheel and where on the flywheel should the key way go sinc ethe motplatt has none?
hey Moose Nuckel..here ya go
http://www.pentonimports.com/install.htm
i got it on and roughed in jus nee dto fine tune it
Make sure you space the flywheel from the stator using a folded over piece of paper or something like that to center it before you tighten the bolts. It will prevent the flywheel from rubbing and ruining your ingnition.
good tip there chris!
Def. great tip. Them guys at Penton are top notch in the tech area too if you need info.
