Results 1 to 2 of 2
Thread: 85 dx carb problem.
    Jan 2008
    Illinois
    13
    85 dx carb problem.
    Ive taken this carb off and cleaned it 3 times, im missing something or something is just broken. It wont idle, it pours gas from the bowl overflow valve except when giving it gas. It wont leak at all then. If you return to where it should idle it will want to die and it will pour gas out of the overflow valve again. If its in gear it will idle normally but still pour gas. Riding it will make it stop pouring gas. Ive looked at a few pictures of manuals online and the float is not upside down. Any ideas what i can to do fix this? Possibly a bad over flow valve screw? Something different i need to look at?
    DIGGER DOG is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    in the sticks s.w ga
    446
    Replace the float needle and seat If the seat is replaceable and adj your float height.
    83 YTM 200,84 200X,,85 350X basket case,86 350X parts trike,86 350Xroller needs top end, 86 250SX,
