I finally got my Tecate running again, she's been down since the day before Thanksgiving. I replaced the stator, flywheel and coil. I think I have the timing a shade too advanced, there is a small amount of kickback you can feel, but she starts and runs. May be even faster with a bit of timing advance like it is. Anyway, I finally put on the 4/110 hubs I bought from BMG a while back and mounted a set of 18" Turf Tamers on 8" wheels. Now I have the badass setup I've been shooting for. I took it out riding Sunday and wow I'm now geared way too low for the 18s. I'm geared 14/38 and used to run 20s and loved the gearing I had.
Options are few so far away from stock gearing, I did find a 34 rear sprocket on ebay and I've seen 15 tooth front sprockets several places. Anybody geared this high? Can a 15 front fit under the factory sprocket cover? How do I calculate final drive ratio including tire diameter so I can shoot for the same ratio as before. 14/38 w/20s was pretty good, I liked it, is 14/34 with 18s about the same or is 15/38 w/18s closer? There's got to be a formula for this.
Oh yeah, I had forgotten how stupid fast my Tecate is. I've been riding my stock Quadracer allot these last three months while the Tecate was down. I was riding woods trails and some broken open ground and couldn't stay in the throttle more than a couple seconds at a time. Between geared too low and the tight conditions, she was a handfull indeed.
Tecate's forever![]()
Chris
